A digital control system model of the pixhawk quadrotor was constructed in scicoslab along with a continuous model of the quadrotor dynamics (the visual model is an arducopter). The user can input the guidance commands to the autopilot through sliders. As the video shows, the yaw response it not optimal, which also happens in the actual system. Using the mavsim Scicoslab toolbox (https://github.com/openmav/mavsim/) , the model can be simulated and then, once the system has been correctly identified, the dynamics can be linearized. The linear model of the system makes the problematic modes clear and aids in designing an improved controller.
    @ UFO-MAN, a virtual machine running the latest ubuntu or debian release is your best bet right now. We have mac almost working on cmake and mingw version for windows could be possible if we get some more interest.
  • @ Hyon_Lim
    I have experimentally implemented MPC in Quadrotors. You are right about the computational complexity but this is something that can be accomplished using model embedded CPUs.
    @James Goppert
    I'll send you some articles on the topic of optimal parameter selection. Give me one day to collect.
  • Hi UFO-MAN.
    Yes. That paper is right. But you should note that the paper does not include about MPC.
    The reason why I recommend that paper is to experiment various control algorithm.
  • Cool Project.
    http://birdeye.dk
  • Hi Hyon, is it this paper (Full control of a Quadrotor) http://www.scribd.com/doc/35698632/BL-Full-Control-of-a-Quadrotor you are reffering to in your above post?
    Is it possible to run Scicos with the Mavsim toolbox on Windows or do I as an alternative have to run it on a virtual Machine running on XP with Linux as the guest OS? (I would like to have access to it on my Windows box).
    ufo_man
  • For the model predictive control, maciejowski's book is the best.
    However, I think it is impossible to apply MPC in quadrotor, because the computation load is high.
    Usually, control input is generated by solving Quadratic Programming (QP). Not easy to implement it in C.
    And the model accuracy will be far from true model.
    Linearization point. That's good. But, seems not easy to implement.
    For the papers, Full control of a Quadrotor paper is good starting point.
  • Hi. This is very interesting work. Our group also working on the modeling of quadrotor.
    However, how did you measure the Ixx,Iyy,Izz of the quadrotor? Using solidworks?
    and can I have your e-mail address to contact further?
    And can I see the model equation that you used?
    Sounds interesting. Any good papers you can point me to?
  • Well you could optimally select the different linearization points and guarantee smooth transition through Linear Matrix Inequality optimization. I have worked on something similar using Model Predictive Control on Quadrotors. I will check your code - thanks James!
  • Now I am completely out of my depth but I did ask for it..
