This is just a repost for those who are new to ArduPilot:
Here's a very simple Arduino program that will test your XY and Z sensors. Just load it on ArduPilot (make sure the board is powered and the GPS is not connected). With the FTDI cable connected, click on the serial monitor icon in Arduino and make sure the speed is set for 9600. The program will prompt you to tilt the sensor in certain directions and then strike any key and hit return when you're ready to take the X and Y sensor readings. Remember that sensor readings inside and near heat sources (like your hand) are nothing like the real thing outside. But it's still a good way to confirm that your sensor is working right. Once you're finished, reload the ArduPilot code.
Thats quite easy program and good idea to test the sensors on analog port . I have just fried out my arduino board by giving opposite supply connections by mistake. I have ordered a new board so waiting eagerly to test the sensors....... Any method to test the chip whether fried out or not..? All pins are giving 3.75 volts on powering up the board.
This is the one i use for quality test in AttoPilot sensors, you must set the speed to 57600bps.
You should read values around 512 with max min of 300 and 700 if you move it around. If you stop moving them the values should be steady, if the values are jumping around is because they are damaged.
And MINE leave the values steady in the terminal so you can read them without changing/moving the printed values left and right. =)
InfraredBoards.zip
