Just press start & it flies itself. A self contained autopilot was the goal.
There were a number of options. Wifi ended up having too many dropouts to be used in any feedback loop, but would have to be used when communicating with a tablet.
So all the intense vision processing had to be done on the camera mount, wired to the cameras. The camera mount required an access point to communicate with a tablet for the user interface.
In the old days, this would have required an FPGA or DSP with custom software. The computational requirement meant the STM32F407 was completely out of this project. Nowadays, a 1Ghz linux board computer with webcams & a wifi dongle is the easiest, cheapest way to do it.
The pi only reached 900Mhz, regardless of active cooling. The complete flight software without user interface used 80% & 1.5A with a cooling fan. With a user interface connected over the network, it used 90%.
Using an LM317 to convert 12V to the 5V was the most reliable power supply. Amazing for all its hardware multimedia for set top boxes, it can barely do machine vision. According to the goog, this is the 1st time anyone has ever done anything that couldn't be done without overclocking it.
The mane task was completely removing the flight software from the GUI, making the entire user interface connect through the network, then removing the user interface completely. The dual camera machine vision maxed out at 320x240 30fps.
Certain uses of memcpy to shift a buffer by 1 byte don't work on the pi. You need for loops.
Now some useful commands:
Steps to bringing it up:
log in as
user: pi
passwd: raspberry
enable root login:
sudo passwd root
step up to 1Ghz & reduce video RAM:
raspi-config
/boot/config.txt contains the settings
enable static ethernet:
vi /etc/network/interfaces
change
iface eth0 inet dhcp
to
iface eth0 inet static
address 10.0.0.11
netmask 255.255.255.0
gateway 10.0.0.9
disable swap file:
vi /etc/init.d/dphys-swapfile
fix slow ssh login:
vi /etc/hosts
Maximum CPU speed:
echo userspace > /sys/devices/system/cpu/cpu0/cpufreq/scaling_governor
echo 1000000 > /sys/devices/system/cpu/cpu0/cpufreq/scaling_setspeed
Download cross compiler from:
https://github.com/raspberrypi/tools
For some reason, they make a software floating point compiler. Only download arm-bcm2708hardfp-linux-gnueabi.
To get the CPU frequency in khz:
cat /sys/devices/system/cpu/cpu0/cpufreq/scaling_cur_freq
Manually set the speed in khz:
