The Multi-Remote Switch is essential for all R/C models, car/boat/heli or plane. Dont worry if you dont have a professional transmitter to control your FAA lighting or bomb drop
system, with the Multi-Remote system you can control 7 Remote switches
at the same time, plus its very easy to use. You just need 1 spare
channel on your receiver and the system controls 9 different outputs.
Great for controlling LED lighting, rocket launches or other on/off circuits.
Specifications:
Input voltage: 6~12V
Weight: 15g
Price is US$ 9.94 and it is available from Hobbyking
Specifications:
Weight: 15g
* Can take two cells or three cells li-po, You have to get a separate power source for it (6 - 12 V).
* You can control each port individually, no need to go throw one two three.. yo can choose in flight what port you want right now, for example: three seven then five.
* It has over discharge protection for the battery (only current discharge no cutoff protection).
* There are 10 modes to choose from see manual 1-4 is good for rockets, 5 to 9 is permanent on/off to turn on LED's for longer periods of time, when 1 -4 mode is selected it will short the port and then with an ignition it will burn it and fire your missile.
* Now go and do a real firecracker FPV battles to the death! oh you have two spare channels? that's 14 rockets on the go!
