Releasing NavStik, a Micro Navigation and Control Module
3689479390?profile=originalWe are glad to announce the release of a micro navigation and control module to serve as an autopilot for UAVs/MAVs. NavStik is one of the smallest and most powerful such platforms available with open-source RTOS based software/drivers that can be used for a variety of applications related to mobile robotics.
This module is intended for use by researchers and hobbyists. All the firmware and drivers are available in open-source to help users start building their applications, quickly.
Key features of this module are:
  • 3-axis Accelerometer
  • 3-axis Gyroscope
  • 3-axis Magnetometer
  • Barometer (Static Pressure Sensor)
  • GPS
  • Temperature Sensors for Temperature Compensation of Sensor Data
  • Cortex M4 Based Microcontroller (STM32F4: 32 bit, 168 MHz)
  • Onboard SPI Flash with 16 Mb Memory
  • Connectors for Interface Board (required for power and interface to external world)
  • Connectors for Gumstix Overo® (optional - available from Gumstix; for power intensive applications)
  • Connector for GPS Antenna (optional; required for GPS applications)
  • Differential Pressure Sensor (optional; for air-speed estimation)
  • Power Regulators and Switches (for programatically controlling power to subsections)
Interface board (IvyPRO) provides following additional features:
  • 12 PWM channels: In/Out Reconfigurable
  • Micro-SD Card Support
  • Telemetry Port (UART)
  • 2 Full-Speed USB Ports (one can be used for firmware upload)
  • Port for Spektrum Receiver (UART)
  • Gumstix Overo® UART and USB (2 nos) ports
  • Debug Port (for connection to IvyGS for JTAG debugging and console)
  • Onboard current measurement
  • Battery voltage monitor
  • Efficient DC-DC converter for wide input voltage range (4.5 V - 14 V)
  • Automatic power switching between USB and Battery
  • ESD and short-circuit protection
The ground-station board (IvyGS) connects to the interface board using the debug cable, and provides these functions:
  • JTAG debugging
  • NavStik console
  • Overo® console
  • Telemetry port for GCS (UART)
A suitable interface board may be selected based on the application. A debugging (JTAG) and ground-control-station board (with telemetry interface and console) is also available. For more details please checkout the community portal: http://www.navstik.org. Limited boards are now available and can be ordered from the NavStik store: http://www.navstik.com.
We look forward to feedback from the research and hobbyist community on NavStik and how would they want it to evolve. Please do leave your comments below or write to us at info@navstik.org.
  • @Aleksey: Thank you for pointing out an interesting piece of hardware. We understand that the market is flooded with options for basic UAV applications. For many such applications, maybe the features offered by these boards will suffice. However, NavStik has been designed for applications demanding highest performance in smallest size with modular design. Along with the main-board, NavStik also offers a range of interface boards (each for a different requirement) and a GCS/debug board.
    For example, looking at the board that you have pointed out, we see that NavStik offers the following extra features:
    • On-board high quality GPS (Ublox)
    • Plug-in support for Gumstix Overo
    • High-quality differential pressure sensor available as option (plug-in)
    • Higher resolution accelerometers (16bit vs 14bit)
    • Separate configuration data memory (16Mb SPI-Flash)
    • Software-controlled power-switching for different subsections (for reset/power-optimization)
    • 33% smaller size, with all of above. I am, of course, not counting the interface board :-)
    • Modular design with 3 ready options for interface boards
    • Optional compact GCS hardware available (JTAG + console + telemetry)
    • micro-USB port for direct firmware upload (via interface board)
    • Advanced power management (via interface board)
    • Wide input-voltage (via interface board)
    • uSD card support for data-logging (via interface board)
    • Several ports (2 UART, 2 USB, I2C, SPI) available for interfacing with other hardware (via interface board)
    So, for serious automation applications that need a powerful, clean, compact & modular system, NavStik does not seem to have a match.
    Users can pick a system that best meets the requirements of their application.
  • @Joe: ST-Link/Discovery or other JTAG debuggers certainly provide same debugging features. But, these do not offer other functions, i.e., console access (2 consoles, one each for NavStik and Overo, for use during development), and GCS Telemetry interface. So, you will need more hardware to help you with those. NavStik (IvyGS) provides a very clean and compact solution for all these functions, that are required for any development program.
    We provide drivers and base-code for ChibiOS RTOS.
  • Hello Veikko,
    No, there is no application specific code bundled with NavStik. It comes with drivers for all sensors/interfaces to help users integrate/build their own applications (any advanced mobile robotics application, including UAVs/MAVs). There are now several good open-source GCS codes available. Users may integrate an existing code or develop fresh code, depending on their requirements.
  • @Joe: Thanks for your comments. We will be uploading software on github and will provide all the details within the next few days. Each of the boards you have listed has a slightly different design and has been optimized for a different set of parameters. NavStik is about power (F4 + Overo), size (smallest, lightest board available) and modular design (three ready options for interface boards, or design your own). NavStik also offers a ground-station board that provides JTAG debugging, console (NavStik and Overo consoles), and telemetry functions.
    @Will: GPS is on-board. It only needs an external antenna (patch antenna) that is available as an option. There are a variety of GPS antenna available in the market (different type, weight, size, gain). Depending on the application, the user may either pick the one available on the NavStik store or use another one from a different source. Based on user feedback, we might carry a few other GPS antenna options on our store, in future.
  • Hello
    There is a cheaper gadget on the market.
    look at
    http://www.universalair.co.uk/
    The combination of the modul called Seraphim and Forebrain will not cost this much. But the adwantage for me ... the IMU is seperated from the mainboard. And it is only a little bigger.
    Kai
  • @Curt: Forgot to mention, IvyPRO takes care of all voltage conversions (1.8V logic level of Overo and 3.3V logic level of NavStik) required for communication. IvyGS also does necessary conversions to enable Overo console on the PC (via IvyGS's USB port).
    I hope, I did not end up confusing you. We will add more diagram and videos to explain things better.
  • @Curt: The max sampling rate for the gyros is 8k/sec and for accelerometers is 1k/sec. You can find more details on inertial sensors used on NavStik here: http://invensense.com/mems/gyro/documents/PS-MPU-6000A.pdf
    Overo will connect directly to NavStik main board. However, access to Overo's communication ports is made available by IvyPRO or IvyLITE interface boards (IvyEZ does not provide Overo support). NavStik communicates with Overo by fusing the USB or UART ports of Overo and NavStik through the interface board (check the image here: http://navstik.org/documentation/1.0/8/ivypro/). No ports are directly connected on main board. This has been done on purpose to allow maximum flexibility on how you want to use the communication ports (for making Overo talk to NavStik or for making it talk to any other external devices). 2 USB ports and 1 UART of Overo are made available by IvyPRO. 1 UART (UART3) of Overo connects to IvyGS (ground and debugging board) via debug cable to provide Overo console on the PC.
    Fail safe mux for RC receiver in NOT built-in.
    Your project looks really cool. In fact, it is the kind of application that NavStik has been designed for! You will love NavStik because it will take care of Overo power, console (via IvyGS) and help you easily fuse required ports between Overo and NavStik in an extremely small and light package. Of course, NavStik also offers a very powerful micro-controller and a great set of sensors. This is how NavStik with IvyPRO and Overo looks like:
    3692513156?profile=original3692513147?profile=originalThis stack (with NavStik, IvyPRO and Overo) weighs about 17-18 grams. If you replace IvyPRO with IvyLITE, you can get it to weigh about 12-13 grams.
    You will need USB bridge and UART Cross cables for fusing respective Overo and NavStik ports. These cables are included in the PRO Pack or can be ordered separately.
    I know the online documentation needs more information :) Please bear with us. You should see a lot more information on www.navstik.org within a week.
  • Hi Nitin: what is the sampling rate of the sensors on your module?  If I am interested in connecting a gumstix (overo) com.  Does it come with the connectors right on the board or do I need to get an expansion board for that?  Specifically how does the navstik communicate with overo (what overo interface? what data rates?)  Does it have fail safe mux circuitry on board?  I have recently updated my overo based autopilot to run with an APM2 as the sensor head.  I wrote a 5-part blog series starting here: http://gallinazo.flightgear.org/uas/ardupilot/hacking-the-apm2-part...
    I had a very successful flight this past friday.  Your hardware is interesting because it is so compact and if I understand correctly has a direct interface to the overo?  But it's always the details where things get tricky and hard.
    Hacking the APM2 Part #1: Introduction
  • @David: The main module weighs about 4 grams (without differential pressure sensor), and 5.4 grams with all sensors. The interface boards weigh between 3.2 and 8.6 grams. So, depending on the interface board you choose, you can get the complete autopilot hardware between 7.2 and 14 grams. Oh, and you will need to add an appropriate GPS antenna (and telemetry module), which will add a few more grams, depending on the one you choose.
  • @Crashpilot1000, @Peter: NavStik has been designed for quality and performance, and is one of the most powerful systems available, while being the smallest and lightest, at the same time. It is meant for serious automation applications, including applications where a Gumstix Overo® needs to be integrated in an autonomous MAV (sub 100 gram) for heavy processing. To the best of our knowledge there is no other hardware platform that provides this functionality, today.
