I finally got my mods to a point where I'm comfortable with others testing. I've only been using it with XPlane seen as it is so dang cold and snowy outside. You need to define OSD_PORT and OSD_MODE_CHANNEL. OSD_MODE_CHANNEL will allow you to assign a toggle switch to turn on and off the OSD overlay while in the air.
Some of the features included:
- Auto-home saving from init_home()
- Distance and direction to home
- Artificial horizon
- GPS LAT & LONG
- Control mode and next waypoint + distance (working on relaying takeoff, land, etc messages)
- Overlay on/off via Tx switch
Here are the Remzibi Mods:
| APM_Config.h |
#define OSD_PROTOCOL OSD_PROTOCOL_REMZIBI
#define OSD_PORT 3
#define OSD_MODE_CHANNEL 7
| ArduPilotMega.pde |
Medium loop, case 3:
#if OSD_PROTOCOL != OSD_PROTOCOL_NONE
print_osd_ahrs();
#endif
Slow loop, case 1:
// Output OSD Data slow loop
print_osd_data();
#endif
// Read OSD Mode Switch
#if OSD_PROTOCOL == OSD_PROTOCOL_REMZIBI
read_osd_switch();
#endif
| defines.h |
After GPS type defines:
// OSD type codes
#define OSD_PROTOCOL_NONE -1
#define OSD_PROTOCOL_REMZIBI 0
| commands.pde |
After line 251, bottom of init_home():
// Save Home to OSD
osd_init_home();
#endif
And finally add the following file into your APM folder:
OSD_Remzibi.pde <-Version 1
OSD_Remzibi.pde <-Version 2
And for my Remzibi layout:
Blake,
Thanks for the good work.
Can we power up the OSD from the APM Board using the telem port ?
Ask direct from remzibi itself from rcgroups forum:
http://www.rcgroups.com/forums/member.php?u=41254
Hi Guys
Where can i get one of these Remzibi OSD Units
Pete
The horizon tilts to the wrong side. ;-)
1
2
3
4
of 4 Next
