Repairing an AeroQuad Motor Mount
I attended the Bay Area meetup last weekend.  One interesting thing that Chris Anderson mentioned was his philosophy that it's often more important to make things that are easy to repair than it is to make things that can't break.
I almost immediately had an object lesson in this by crashing my quad.  Two props were broken, so I put it in the car to take care of later. When I got it home, I noticed that one of  the motor mounts was bent to an almost 45 degree angle.  Fixing it took less than a minute.  Thanks AeroQuad!
http://eastbay-rc.blogspot.com/2011/04/repairing-aeroquad-motor-mount.html
    Nice one, Mark! Just to elaborate on the philosophy, it derives from a desire to keep weight down. You can make a nearly indestructible quad airframe, but it will be a tank, with a high cost to flight time and maneuverability. Better to make it light, but with "crush zones", cheap and easy to make/buy/fix parts, and a design that is intended to fall apart on impact.
    For example, the Guai 330 quad is made up of lots of fiddly carbon fiber pieces, which all snap together. It falls to bits with every hard landing, but can be snapped back together in seconds. Likewise for the Raven, which "stall lands" and typically falls into between three and six parts on impact.
    The ArduCopter arms are made up of very thin aluminum, which tends to bend in a crash. Some people prefer thicker, stronger aluminium, but that makes for a heavier quad. I'd rather stock up on cheap spares and have the longer flight times for the light frame.
