3689623455?profile=original
Today we were having a discussion about aircraft control via different flight modes. Personally would prefer to change the way input happened when controlling the UAV directly, so that the input is more intuitive in nature. I have seen allot of really well designed controllers recently however little that changes much of the traditional levers and dials, and nothing a single puck. Maybe there is something to that Star Trek control. Above is just a quick conceptual collage. The base was squished as you can see the original here, and was quickly modified to stimulate thought on how a typical RC twin 2 axis stick design could be evolved so that a more intuitive control can be developed. The center puck above is a true integrated 6 axis control, all that can have coordinated intuitive movements for the UAV.
3689623518?profile=original
Here is some of the verbiage from the 3dconnexion.com:
"Superior 3D Navigation
SpacePilot Pro’s patented 6-Degrees-of-Freedom (6DoF) sensor is specifically designed to manipulate digital content or camera positions.
Simply push, pull, twist or tilt the 3Dconnexion controller cap to intuitively pan, zoom and rotate, while your other hand simultaneously uses..."
Ordered one today to take it apart, and see how I can hack together a solution, possibly integrating a board computer and a small wifi-bridge/ap so that it can be used as a integrated base station.
It seemed obvious since the object we are controlling actually operate in a 3D environment that the controller especially when operating FPV or "First-Person-View" should be able to translate that intended movement as turn left right, up down, and with a few that could be atypical due to the way and coordinated function of the device and its ability to tilt or go sideways, possibly to engage linear thruster type dives.
The Myo and the 6-Axis mouse will be a fun combination, it will be interesting to integrate tactile and and virtual gesture based movements.
Dev Team
Digi-DNA.net
  • We are glad this thread is moving the right direction and of course we are happy to read these nice comments.
    I say " We" because my ideas would have gone nowhere without David and Tiago and also 3D Connexion, who supported us with the hardware and a few goodies ( we broke a few keyboards and sensors lol) since the very beginning with Raik, Uwe and Antonio now at 3D connexion, it's a team work since the beginning and my only hope is that all the hard work these past years can lead to something concrete soon for all of the contributors in this project :)
    I will try to post a video of the system with the 3DR flight controller as soon as possible :)
  • Tearig, I agree. The attitudes on here are really positive and it's really good to see alternative approaches towards the same goal.
  • Sometimes the universe suprises me this time is no differnt, the distance covered in just the short time since I made this post has realized so much benift and I am so grateful to all that have contributed so far!
  • Hi,
    there is one variable that we did ignore for a while and it was an important one, when we started the project : People used to Rc transmitters ( standard ones) like us ( i fly Helis and planes and of course multirotors) have the "coordination" set in their head already, so it is in fact harder for them to use the 3D sensor at the first time. This had to be put aside when we made the tests with "normal" people with no flight experience.
    If you want to fly artistic or 3D, then yes, maybe a Rc transmitter could be better of course. But if you want to fly a " Tool" or simply follow an object or a path, then, the 3D joystick is way better, because it's simply like moving an object in space.
    Throttle or pitch are used normal to stabilize altitude. But if Altitude is stabilized with a barometer, or a Gps, then you do not use it that much for mapping construction sites, fields or survey.
    Standard mission is, in most cases : control the machine during hover and get it into position, then switch to auto pilot or use GPS or self leveling ( compass or accelerometers) assistance, use barometer assistance, and move the UAV along a simple path to observe, take pictures or others. Add Carefree / Intelligent orientation control, and honestly, this is just as simple as that to fly a mulitrotor or any Vtol equipped with a decent flight controller.
    Most people flying for survey / observation or mapping do not use a lot the throttle except when taking off and landing.. But Throttle / altitude control remains very easy even with the 3D sensor.
    Also, we could notice that "standard" users ( who never flew a rc model before) had all time a better coordination in the 3 channels ( rudder, aileron and elevator) when using the 3D sensor than a regular transmitter, because they didn't have to triple check each axis on each stick's coordination during the time they wanted to perform the maneuver. They did it, simply. Everything else is a matter of deadband, sensibility, exponential and flight controller setup ( Tiago Inside lol) and experimentation with as many people as possible.
    All of the " testers" have been invited to test the system this way : on first tests, we had trainer cord between the system and a regular transmitter. We hovered, and then placed the multirotor at 20 meters altitude around, in GPS with carefree  and gave them control on the 3D sensor. We just told them to keep it smooth and experiment, and release if anything went wrong. After one minute or 2, we switched to " attitude" ( self levelling / altitude control, but no GPS and no carefree) and helped them a little, gave them advises ( keep nose pointed forward, try to keep position...), and after a few minutes most people were already able to fly pretty well already, some of them were even able to land with no GPS control. After 3 or 4 flights they could bring the machine almost everywhere they needed to. With our 2 Super Grannies ( 70 and 74 years old) that we met at the field at CEEMA, well it was a real blast, they did not want to stop flying and even landed on their own at the very first flight. That was the coolest thing in all our experimentation, to see them so happy and enjoying flying a multirotors. Kids loved it also a lot :)
    Now we do not use trainer transmitter anymore and directly give the joystick to the "tester" , and we had no troubles so far.
    We do it even indoor at the workshop when some people come to test it, and nobody crashed anything so far ( lucky me..) :)))
    We learn them how to fly without GPS assistance and after some time they can fly even manual for some ( full manual, no self leveling).
    If you want the to do the same thing with a standard transmitter, they need almost one week of training to do this.
    The very first goal was ( and is reached now) to allow anybody like a firefighter, a policeman, a soldier, to control a UAV or Rover for survey or observation, to fly with no extensive training with a Rc transmitter, and always keep the same " logics" with he control system. As it was pretty successful we did let interested persons wanting just to fly a multirotor testing it and well they like it over standard Rc transmitters and unlike us, they are absolutely not bothered by the multiples axis being handled in just one input device.
    Then we have modified the sensitivity to allow partialy disabled persons, especially children, to fly a multirotor, just for fun.
    And then, well, we just moved forward :) There are 3 different versions of the system up and running actually, one super portable version, the standard one and a mission oriented one.
    It is true that it is better to have a heavy "base" to be able to have perfect control at the beginning, but well there are several ways to make things work ok..
  • Here is a picture of the very very first rendering after talking for ages about the concept we had with David (this first rendering was made by David on the 3rd of May, 2012). Wow that was long time ago... Then Tiago jumped in and brought the missing " magics" and so did 3D connexion by supporting us since the very beginning ... Things have evolved a lot since that time :)))
    We bought a 3DR Pixhawk to hook it on the system last month  (Actually we programmed all the functions for Naza / Wookong / A2 and Mikroktoper / Autoquad) , i'll fit the 3DR Pixhawk on the second Little Spyder we have here from Sky Hero (i do not have an Iris + at the moment, sorry ..) to give it a try during the week end.
    By adding a Hall sensor rotary wheel (or potentiometer based wheel)  it is also possible to manage very well fixed wings things (for Rovers it works in any configuration) .
    3701863709?profile=original
  • Having and excuse to travel to the South of France is a good thing, sent you a PM
  • I just forget to say, that there is no need to have 2 sensors to control the multirotor and the camera, depending on the use you ave of it. But we have a mini sensor for gimbal or payload that can be simply added :) System is compatible any flight controller on the market also and also on some military controllers. it can me custom modified anyway like any electronics.... :)
  • Hi,
    as Tiago said, we work on such a thing since long time now. We are 4 involved in this project : i made the first sketches, submitted to David Cook, my partner in USA, who jumped on the boat and we worked further, then we found nobody we could trust enough to work on the code until Tiago arrived, and finally 3D Connexion themselve. it has been a long way to find out how to setup the sensitivity, Tiago worked a lot around the code and well all we can say is that ti's working, and way beyond our expectations.. We did not plan to talk about it before the product release but well with this post we had to say something lol ...
    What we have learned from all prototypes is that RC transmitters as they re are totally obsolete for multirotor usages, and it is very intuitive ( by the way we created " Intuicontrol" company for this particular product).
    We have full telemetry and many useful features and functions also..
    Different versions have been made, but pictures of final products will be released only once the product is in stock and available, we had way too many people ripping off our work the last years because we showed too much, too early ( well this is called " learning business "..) . All i can say, that that we worked damn hard with Tiago and David, and had great support from 3D Connexion since 2012, we continue to work with them and we are preparing something with Sky Hero at the present time, i think this will be the first " version" that will be available on the market.
    If you travel in south of France you can come in and test the system by yourself, we will just ask the person to sign a NDA before testing the system for IP protection.
    Best regards,
    Fabien (E-copter)
  • send it on, like the integration. and now with the space pilot anxious to fly the UAV using the 3d Mouse
  • Alex, does the large joystick twist also? 3 rotations 3 translations kind of thing?
    When I think about controlling flight it seems natural to have a dial/rotation (3rd) and 2 axis movement on the left the rotation being throttle position while directional movement could invoke flight modes, 8 positions should possible. Right hand then can control 3d spacial positioning, with the addition of tilting the rotors the attitude of the fuselage during forward flight changes, this could be scripted via the 6 axis puck for flat forward movements as apposed to pitch and fall, maybe more tilt and cruise. Recently I sent out for some new UHMW parts to be turned so I can finish this setup on the UAV370.
    The looking towards the future forward this may be make a easier transition to control crafts when gravity is not a factor since directional control is not a function of centralized gravity, rather vectored thrust to change total direction.
