SA 3B - VTOL Drone Pure Wing by Haris Unmanned Systems
13221851672?profile=RESIZE_710x
Elevate Your Operations with Our Long-Range VTOL UAV
Discover the future of aerial surveillance and reconnaissance with our cutting-edge
VTOL UAV. Designed for versatility and endurance, our drone boasts an impressive
flight range of 1200 kilometers and an operational endurance of 15 hours.
Haris Unmanned Systems (HarisUS) has made its mark with innovative designs and locally manufactured drones tailored for industry-specific needs. Among their standout creations is the Pure Wing SA 3B, a VTOL (Vertical Take-Off and Landing) drone that combines precision engineering, advanced AI capabilities, and versatility to address diverse applications.
This state-of-the-art drone is designed to serve industries such as oil and gas, construction, mining, and infrastructure monitoring, delivering performance and reliability that redefine what UAVs can achieve.
Technical Specifications of the Pure Wing SA 3B
Design and Build
Material: Lightweight carbon fiber for enhanced durability and reduced weight.
Wingspan: 3.2 meters, optimized for aerodynamics and stability.
Weight: 12 kg (without payload), allowing for portability without compromising robustness.
VTOL System: Features powerful, efficient rotors for vertical lift, seamlessly transitioning to fixed-wing flight for extended range and endurance.
13221883285?profile=RESIZE_584x
Flight Capabilities
Maximum Range: Up to 120 kilometers in a single flight.
Flight Time: 4 hours on a single charge, aided by energy-efficient propulsion systems.
Maximum Speed: 80 km/h, balancing speed and stability for various operations.
Payload Capacity: Up to 5 kg, allowing for diverse sensor and equipment configurations.
AI and Navigation
AI-Powered Autonomy: Features advanced navigation algorithms for obstacle detection, route optimization, and automated return-to-home functionality.
GNSS and RTK: Equipped with high-precision GPS and Real-Time Kinematics (RTK) for centimeter-level accuracy in mapping and surveying tasks.
Obstacle Avoidance: Multiple onboard sensors, including LiDAR, ensure safe operation in complex environments.
Payload Options
  • The SA 3B supports a range of payloads, including:
  • Thermal Imaging Cameras for pipeline and building inspections.
  • Multispectral Sensors for agricultural monitoring.
  • LiDAR Systems for 3D mapping and surveying.
13221887258?profile=RESIZE_710x
Software and Connectivity
Real-Time Data Transmission: Supports long-range data links for instant analysis.
Customizable Mission Planning: Intuitive software for setting up and executing complex missions.
Cloud Integration: Enables secure storage and sharing of collected data.
Applications of the Pure Wing SA 3B
The Pure Wing SA 3B is engineered to excel in challenging industrial scenarios, making it a trusted asset for:
Oil and Gas Inspections
Perform pipeline monitoring, flare stack inspections, and offshore platform surveys with thermal imaging and real-time data analysis.
Infrastructure Assessment
Inspect bridges, buildings, and other critical structures efficiently and safely using advanced sensors.
Mining Operations
Conduct aerial surveys, monitor excavation sites, and generate precise 3D maps of mining areas.
Environmental Monitoring
Track wildlife, monitor environmental changes, and survey disaster-affected areas for rapid response.
What Sets the SA 3B Apart?
Haris Unmanned Systems’ focus on local manufacturing ensures the Pure Wing SA 3B is designed specifically for the demands of industries in Saudi Arabia and the GCC. Its AI-driven features, coupled with a robust VTOL design, make it a leader in UAV technology.
Additionally, the SA 3B’s modular payload system allows businesses to customize the drone for their specific needs, providing flexibility and cost-efficiency.
13221889475?profile=RESIZE_710x
A Commitment to Excellence
The Pure Wing SA 3B is more than just a drone—it’s a testament to Haris Unmanned Systems’ commitment to innovation and quality. Manufactured in Saudi Arabia with a deep understanding of regional needs, the SA 3B is perfectly aligned with Saudi Vision 2030, empowering industries with advanced technology to drive growth and efficiency.
Whether you’re in oil and gas, construction, or environmental monitoring, the Pure Wing SA 3B is built to help you rise to new heights—literally and figuratively.
For more information, visit https://harisus.com/
https://harisus.com/saml
