sentinel-rc-strobe.jpg?width=450
 Sentinel is our new battery monitoring product. It is checks your battery in midflight and additonally, it is a navigation & strobe led light system.
Sentinel has some cool features like checking cells of your lipo battery and total energy of it.If a cell or total energy drops down, Sentinel warns you.
 Detailed information at Copterframes.com
  • Let me have a look now, running down a small 3s battery with sentinel attached.
  •  all of yours are same , actually I changed new items with your suggestion. what is the problem with others? we checked them before shipping...
  • Thanks Ozan,
    Not sure if that shipped out on my order of 3 Sentinel's.
    Is it possible to change that?
  •  Actually you are right, no yellows,I canceled the yellow signs because yellow and green looks same at midflight.
    Voltage lines are changed a bit with your suggestion :
    Over 3,9V = Green
    3.9 - 3.7 = Solid Purple
    3.7 - 3.6 = Purple Flash
    Under 3.6 = Red Flash
     Wiring :3701986285?profile=original
     Greetings
     Ozan
  • Hi Ozan,
    I'm trying to figure this thing out... havent seen it go yellow yet.
    Can you take some pictures of how it should be wired?
    And examples of low voltage warnings?
  •  Ok,
     I like your colors and will do,why not?
    Maybe your idea might better... :)
    In navigation mode, only cell droping alarm, yellow and red alarm will be available.
  • I see navigation strobe is for night flying, but will that tell cell voltage as well?
  • That would be excellent. So it would just occasionally read out of my voltage of cells in "navigation strobe mode"?
    My ORDER TDTXGZLSR. I essentially just want it to:
    Flicker Green for 100% (4.2 - 4.0)
    Flicker yellow for 75%  (3.9 - 3.7)
    Flicker purple for 65%  (3.7 - 3.6)
    Flicker red for 60% (3.6 - 0)
    Let me have another look at what navigation strobe looks like.
  •  I can arrange code default "navigation-strobe mode" for you. If you dont want to use rc ,it works navigation-strobe and you can use rc for other modes when you want.
    Greetings
     Ozan
  • I see,
    I just ordered 4 of them to test out, curious to see this in action as I think it will help for night flying quite a bit.
    If I don't leave it plugged into my receiver can I leave it in Navigation mode then unplug from receiver?
