The new small size UAS Skyhooks 1700 UAV
It's made in strong white EPO foam just like most hobby models these days.
Wingspan: 1718mm
Body length: 1100mm
Wing Area: 45.5dm2
Empty Weight: 1050g
Material: EPO Foam design
0.2-0.3:1 Thrust to weight ratio.
Easy to assemble and disassemble.
Easy to transport.
This plane carrying 4s battery the take off weight is only 2.4KG if installing full line of FPV equipment take off weight is roughly 3KG.
When flown properly this plane can have more than one hour of flight time.
What you get:
Agree. If loaded it with 3 kg electronics and lipo I bed a hand launch would need an oversized motor setup. Then again we like oversized stuff.
I think the wheel with get in the way of the launch, they bungee the real ones so I bet this will struggle from the hand when loaded. That said I fancy one as well.
Oh wow, that picture makes it look much bigger than I thought!
There should be no problem having more than 5000 mAh 4S inside.
Gary@ I will tell you in 5 days. To me the fuselage looks a little thin in construction so it might have to have a thin layer of composite.
Well I think it will get a thin layer no matter what.
I love the fact that it has a wheel on the belly to help it belly land without wearing on the foam constantly. But, it's not to the extent that it has actual landing gear which can be draggy, and fragile.
So what about the 4S 5000?
Might it be a little flexible Hooks??
I doubt if many people will know Robin its just been released.
Any one know what the dome is made of, and how does it handle reflections etc. What kind of picture do you get with a video through the dome? any one?
1
2
3
of 3 Next
