Our precision landing Solo is flying great! :) This test rig has an IR-LOCK sensor (via I2C), an SF/10A rangefinder (via Serial), and is running a customized precision landing firmware based on APM:Copter (solo-rebase). The video above shows two vision-guided landings. The full 10-landing test sequence is shown below. The typical landing accuracy ranges from 0-10cm, even in moderate/gusty wind.
One of the primary challenges of designing a precision landing UAV system is the controls tuning. Every UAV has different flight characteristics, and finding the right PID (+EKF) parameters can be a painstaking process. So it is very helpful to have a popular, consistent hardware platform (e.g., Solo) to develop on. Solo flies nicely out of the box without significant parameter modifications. The precision landing performance is noticeably better than our IRIS+ platform, and our previous Solo test platform (w/out a laser rangefinder). In the 10-landing test sequence, the typical landing accuracy ranged from ~0-10cm. There was only one ‘failure’ (landing #5 out of 10), in which the copter landed far outside of the specified bounds. This will be analyzed and corrected via the controls code.
This test platform is running a customized precision landing firmware, which uses the vision-based localization data to actively manage the landing accuracy. You can read more about the code, and see previous testing here. USER BEWARE: this code is experimental, and it assumes that you have a reliable rangefinder connected.
Customized Firmware: ArduCopter-v2.px4
Github: http://bit.ly/1q3fIvS
Connecting IR-LOCK to Solo: Hackster.io article
I was wondering if anyone has tried to upload this new firmware to their solo drone( besides Thomas ;) )? I have now attempted with 2 of my solos and both are bricked. the first one I though was just a fluke, but the second one has now done the same thing. I upload the firmware, restart the drone, and it goes into update mode doing the rainbow arms for ever, the first time I waited about 20 minutes and then turned off the drone, hoping to just try again, but after restarting I could never get a connection to the drone and the arm lights stayed a constant green. factory reset never worked either. My second drone is now stuck in rainbow mode and I have left it there for there for 30 minutes now. I have uploaded custom firmware before without any problems, any suggestions?
@Grant
Not exactly. I think it would be a more reliable way to determine the AGL altitude above a 'box'. I would still use the IR-LOCK sensor for determining an accurate angle-to-IR-target. We use the AGL altitude and angle-to-target to accurately determine the location of the copter relative to the target.
This is what we demonstrated in the video, but we used a single-beam rangefinder, and the landing area was flat. For 'landing on a box', the multi-beam rangefinder could provide better AGL altitude info.
@Thomas - are you thinking we could add code to detect the "edge" of a platform i.e. one of the corners of the triangle pattern registers 1.5 meters longer so you infer which way the platform probably was?
Thanks, Grant.
@Grant
Also, this multi-beam rangefinder could help with 'land on box' problems. :)
http://www.lightware.co.za/shop/en/products/43-sf33tb-50-m.html
Thanks @LaserDev! Great rangefinders. :)
Great work Thomas!
Thanks, Grant.
The accurate AGL altitude information from the rangefinder is very important when determining the relative location of the copter. i.e., the copter knows how many cm off-course it is from the visual target. This localization information is used to adjust the climb/descent rate if the landing is off-course.
Our previous copter made more aggressive maneuvers (video link), which is a better visual demonstration.
Yes, there are quite a few 'land on box' projects. The flight control code can also handle these situations (although, the linked code is admittedly basic). When the copter is high (3+ meters), the accuracy criteria is relaxed. As the copter enters the ~0-2 meter altitude range, the copter must stay within a specified distance from the target, or it will ascend and re-try the landing.
If the rangefinder suddenly gives a 'bad' (+1.5m) reading, this will also cause the localization info to be 'bad' (i.e., outside of the specified distance from the visual target), and the copter will ascend and re-try the landing. Also, the copter can ascend if the visual target is out of view.
Its looking great. Is the rangefinder installed and configured into the copter in the standard way or is your modified code somehow making use of the rangefinder information to more accurately land and extra configuration steps required? Or is it just an overall advantage as you get much more accurate altitude information from the rangefinder?
One scenario that concerns me is platform landing. I've seen some designs where they have the copter landing on a raised platform - think 1.5m off the ground but only 1x1m landing area. I am wondering what happens when the copter is "blown" slightly off the landing approach and the rangefinder suddenly see's an extra 1.5m of altitude.
Thanks, Grant.
1
2
of 2 Next
