Some MultiCopter Design Thoughts.
3689569662?profile=original
Hi All, Just pulled this image in from SUAS News (Thank you Gary) to illustrate a few really good concepts that it incorporates and talk about better Multicopter design a bit.
This copter has a lot of things right and is really a study in design excellence.
1. Most obvious is a sliding ball full enclosure camera Gimbal, very pro and really something we should be striving for.
2. The motors are on the bottom under the arms: More aerodynamically efficient with no prop wash interference and very little intake interference. Noticeably increased flight times and greater lift capability and much quieter.
3. Large slow high efficiency props and pancake motors: These are way more efficient than faster motors with smaller diameter more conventional props.
4. Carbon fiber aerodynamic frame arms: Again more aerodynamically efficient, light and strong.
5. Fully enclosed framework and a simple spring loaded landing gear that provides as little interference with the prop wash as possible.
Basically this quad incorporates the best design features I have seen so far and definitely provides food for thought.
I thought it might be worth soliciting comments and other thoughts about optimal multicopter design techniques.
Best Regards,
Gary
  • 3701687282?profile=originalBut others are going in that directions,some very close to this community
    Virtual robotics have a great example of aerodynamics and design
    http://www.virtualrobotix.it/index.php/en/prod/bod
    Black Ops Drone
  • I respect everybody scientific results,my experiance is only from flying with props top,and down ,and top-down together and measuring time I was flying...but I must tell you I cant imagine situation where you have 20% lost just bcs. of props above arms or maybe I understood wrong bcs I do agree with 1-2%..
    10-20% would be all lost you have bcs. of coaxial setup...but that is completely different story..
    As I sad before and someone else too,all this discussion is not worth of calculate.
    If you are worried about aerodynamics you better try to find way to make big central part and camera with gimbal more aerodynamically efficient
  • Hi Chris,
    I understand that the answer depends entirely on the setup (frame, motor, prop sizes and distances) but can you give an estimate of how much more power is consumed with props above frame compared to the same setup with props below the frame? Just to have an idea of how much loss of  power we are talking about?
    Thanks,
    Arnie
  • Hi Chris,
    That is entirely consistent with data posted by others as well.
    The situation for a multicopter is that it normally lives in a state of hover.
    So the area above the prop is essentially a static air mass whereas the one below it is very much a moving dynamic air mass.
    Essentially the interference with the intake air is considerably less lossy than the interference with the dynamic output air.
    This is true for hovering vehicles.
    But a dynamically moving airplane generally at least reduces the advantage because the intake air is now also a dynamic moving air mass. (at least when it is flying) that is also dependent on good aerodynamics and minimization of turbulence ahead of the prop.
    One thing you can't get past with a strut, frame arm or beam directly under the prop though is that it has a direct, significant and calculable interference with lift that is at least equivalent to how its effective flat plate area directly interferes with the thrust of the prop (it is blowing against its own lift to that degree) and it is a dead loss.
    Turbulence can make it worse.
    In a stationary hovering craft in calm air, with the prop under the frame arm, especially if it is some distance down, interference with the static air mass can be vanishingly small (and harder than blazes to calculate.)
    Best Regards,
    Gary
  • Nicely written Gary...
  • Gary, as always thank you for your precious technical input on this things, it really does help a lot. I've started to work on precisly engineered assembly of armadilo and this drag coefficient wiki page you've share has really enlighten me what you mean by using just the right size for the job. I'm a designer, i understand a bit of everything but i love to get more into detail when opertunity is presented.
    much abliged
  • With arm above motors/props interference is small but also hard to compute because of variety of forces involved.
    But with arm below, the arms interference is relatively straightforward and is at a minimum the direct interference of the arm with the prop wash because the propellers wash is actually directly impinging on the arm itself with a direct force counter to it's lift.
    A 1" square rod will place 1" of flat plate interference along the entire length of the rod that is under the prop wash.
    That is the equivalent of that percentage of the prop circle that is occupied by the frame arm directly interfering with that percentage of produced thrust (Instead of being applied to net thrust it is actually thrusting against the copter itself in the wrong direction so is subtracted from net thrust rather than added to it.
    This is not insubstantial and generally will vary from 3% to 7% or more depending on arm size versus prop diameter. For a non tapered arm the effect decreases for larger prop diameter assuming same arm size.
    A round arm with the same outer diameter as one side of a square rod has about half the flat plate area of an equivalent square arm straight on.
    Generated turbulence is also added to the loss in efficiency and the net loss can get up over 10%.
    With the arm over the prop, total aerodynamic losses are unlikely to exceed 1 or 2% at most unless it is a very wide arm or very close to the prop.
    What I have said above is generally true for hovering multicopters, losses for an overarm design would increase somewhat during rapid upward movement because you are now interfering with a dynamic airstream.
    Please note Dragans bottom diagram is actually increasing the diameter of the arm to larger than the side of square arm so equivalent flat plate area would be increased.
    Minimum flat plate area is actually achieved with an aerodynamic wing like profile () in fact a raindrop profile is generally highly efficient for a given cross section because it is a naturally forming aerodynamic shape.
    Equivalent flat plate area can be ultimately reduced to less than 10% of the cross section.
    The numbers I have used are not cast in stone, but are at least reasonable ballpark figures applicable to our multicopters in hovering and low speed flight.
    They are likely made worse in all instances by high speed or acrobatic flight.
    Although in continuous forward flight some extra lift may be generated which can actually increase efficiency a bit at some speeds.
    Basically I would use round CF or fiberglass arms where possible of a size appropriate for your copter.
    Generally a prop over configuration with round arms permits other design optimizations and has an inherent practicality that can compensate for the increase in efficiency made with a arm over prop configuration.
    For additional understanding of flat plate area and drag coefficient, Wikipedia makes it clear:
    http://en.wikipedia.org/wiki/Drag_coefficient especially note aerodynamic cross section!
  • Anything rounded that you add to a flat frontal surface has to be better than square.
  • Guyz, since we are talking about efficiency do you think that square arm thrust obstruction could be reduced to match round tubes with simply ataching round foam sticker on top of it?
    3701665575?profile=original
    I wonder if it could work with only one foam sticker on top or would it require one on sideway facing incoming propeller as well, as atached to look in direction oposite of propeller direction shown below.
    3701665900?profile=original
  • Foxtech K130 16kg Fly Time Test
    https://www.youtube.com/watch?v=oZHqz8Y_5Tc
