Hi all,
I want to share some results of comparisons between different GPS modules as well as different approaches for geotagging and stitching images based on APM:Copter log files.
CAM_TRIGG_DIST (blue) vs. adjusted coordinates (green). Stitching is based on corrected coordinates.
The background is that we were aiming for a tool, which would allows us to check the image and geotagging quality immediately after completing a survey mission. So, in case of any camera triggering or geotagging errors (as well as image quality problems) one can repeat the mission again with different settings without having to wait for any complex and time consuming processing in the office. Additionally, I was interested in the positional accuracies one could expect from repeated survey missions and with different GPS modules. Hence, this post focuses on different aspects of positional accuracy. It provides a short summary of our experiments. It is not a scientific study and most of the tests were not repeated. So this is just intended to be a rough guide. Anyway, I hope it will be helpful to some of you.
1) A comparison of the PDOP (Dilution of Precision) values between different common GPS modules for the Pixhawk autopilot
The crucial component for geotagging images as well as for geo-referencing in general is the GPS receiver. There are mainly 2 different u-blox systems currently in use together with the Pixhawk: the LEA 6H and the NEO M8N.
For a test I mounted the following three GPS on my copter:
- 3D Robotics LEA 6H (it is out of stock so maybe something new (M8?) is coming soon…)
- CSG Shop NEO M8N
- Virtual Robotics NEO M8N
Test setup: 3DR LEA 6H, VR M8N and CSG M8N
The major difference between the two M8 modules is that the CSG M8 has a larger antenna (there is a „mini“ version with a smaller antenna available as well) whereas the VR M8 has an additional amplifier. VR M8 was connected to the Pixhawk as GPS1 and the 3DR 6H as GPS2. The CSG M8 was connected to my Laptop via USB directly. I used Mission Planner to monitor the VR and 3DR GPS modules and u-center to monitor the CSG one. Because AC3.2 is reporting is the PDOP and not the HDOP, we need to compare the AC3.2 HDOP with the PDOP reported in u-center. It is also important to set the "Min SV elevation" to the same values. To compare the performance I tested all three modules in parallel. In a first test I compared the performance outdoor and indoor (close to a window).
Results of the outdoor test
- The LEA 6H always shows less satellites and a higher PDOP compared to the other two (~1.7 vs. 1.1)
- The VR M8 is comparable to CSG M8 when the "Min SV elevation" of the latter is set 5deg. If "Min SV elevation“ of the CSG is set to 10deg the VR is slightly better. This is why I assume that "Min SV elevation" is set to 5deg on the VR M8.
- The CSG M8 was the first that got a 3D Fix and it was better for quite a while. Interestingly, the position accuracy of both the VR and the 3DR increased significantly after re-booting the Pixhawk. This is a little strange to me but I experienced this more than once.
Outdoor test: CSG with Min SV elevation set to 5°
Results of the indoor test
- After waiting 15 min the CSG had a 3D Fix.
- After 20 min the 3DR came alive (gpsstatus2 = 3).
- Even after 40 min the VR still showed gpsstatus2 = 1.
- When setting the "Min SV elevation" to 5 on the CSG the results went a little worse and were more noisy.
The indoor results are reproducible. That's why I went outside - I thought the VR M8 was dead but luckily that is not the case. Roberto from VR reckons that the internal pre-amp could go in saturation if there is some interference.
Remarks
- always use an M8 instead of a 6H
- the CSG M8 is the most sensitive
- this must be due to the larger antenna even though the VR has an amp
- the reason why the results went much better directly after rebooting should be investigated, since this is not the case for the CSG one (or at least I haven't realized before) and because it should result in better positional accuracies at least in the beginning of the flight. Since, the VR and the 3DR GPS were connected to the Pixhawk the problem might also be related to the autopilot. Can someone confirm this behavior?
- the outdoor accuracy seems better and less noisy if "Min SV elevation“ is set to 5°. However, with this setting the receiver might be more affected by multipath errors as shown by the higher noise for this setting in the indoor test. Hence, for security reasons 10° might be the better choice.
- There was no obvious difference if a GPS antenna was covered with the 3DR GPS cover or not.
- I haven’t tested it with the VR M8 but the CSG M8 is very sensitive to interference from the bluetooth telemetry module - even if mounted >20 cm away from the GPS. The 3DR LEA is less sensitive.
- All tests were conducted without an additional shielding of the GPS module. A first test with an additional shielding between the VR M8 and the Pixhawk et al. shows marginally higher number of satellites (20 instead of 18) and a little lower DOP values. But this has to be verified. I also have to test if there is a reduction regarding the bluetooth interference.
2) Camera trigger delay and direct image stitching
For many applications a simple image overlay is sufficient. The advantage compared to the generation of orthophotos is that the mosaic can be generated quickly in the field. However, even stitching can be relatively time consuming - especially with large image sets and if image registration is performed using automated image-matching techniques. Hence, we were aiming for an approach that provides georeferenced image mosaics that rely on the GPS coordinates only.
To achieve this aim, we
- fly at a fixed altitude,
- use brushless stabilized NADIR gimbals
- Canon Cameras with CHDK
- and Marco’s circuit to trigger it from a Pixhawk with CAM_TRIGG_DIST.
Hence, the CAM entries in the log file can be used for geotagging the images. The GPS used in all following test was the Virtual Robotics NEO M8N. To achieve optimal image quality the camera settings have to be adjusted for every single image. This results in some delay between triggering the camera and shooting the image.
Direct stitching results
The following two figures (I moved the first one to the top of the post) shows the coordinates when the camera is triggered (blue) vs. automatically corrected coordinates (green) where individual velocities and shooing delays have been factored in. The stitched image based on the corrected coordinates is shown in the background.
The mosaic based on CAM_TRIGG_DIST is corrupted. This is due to the fact that CAM_TRIGG_DIST was set too small in this test in relation to speed and camera trigger delay. Hence, some images were not taken. Normally, there is only some offset. Synchronizing the image time stamp with CAM_TRIGG_DIST time will also help to reduce this effect in case images are missing.
CAM_TRIGG_DIST (blue) vs. adjusted coordinates (green). Stitching is based on CAM_TRIGG_DIST.
Remarks
The comparison between the stitched images shows that
- Geotagging has to be performed carefully to reduce artifacts
- NADIR gimbals provide an easy way to reduce perspective distortions and guarantee the best viewpoint for many applications (e.g. SAR, Precision Agg)
Processing takes only a fraction of time compared to generating an orthophoto. Stitching is completed within minutes on normal laptops.
3) Positional GPS accuracy of repeated surveys
What is most interesting is the positional accuracy between directly stitched mosaics of repeated surveys. Therefore, we repeated missions over the same area at two consecutive days. Georeferencing is performed independently for each image and only based on the GPS coordinates provided by the VR M8. Additional ground control points and image matching routines were not used.
We also tested different cameras so the results show a mixture of potential errors.
The red points in the following image mark same position of different flights.
RGB mosaic, day 1, flight 2
The following screenshots show the potential geo-referencing accuracy without any ground control points and after applying a linear shift (no scaling or rotation) to the images based on Google Earth data. The orthoimage as well as the DSM are perfect. The simple overlay and the mosaic show a small offset/distortion (Some more precise measuring/shifting should result in even better positioning.). Yet, this should be ok for many applications. Because it was snowing during parts of the flight the image quality is rather poor.
Orthophoto
Stitched mosaic
Remarks
The results show that in average the PDOP reported by ArduCopter is a quite good estimator of the offset between single images within one mission (although it is called HDOP for unknown reasons). Positional errors can be seen within each mosaic but most obvious in the RGB mosaic.
The offset between the different flights/cameras in the IR/RGB example is up to 4 m and not linear over the entire mosaic. But, as expected, the offset is smaller at the end of the mission indicating that a longer warm up period (and/or reboot?) should reduce the offset in the beginning of a mission. This is why in many cases the directly stitched mosaic fits the true orthophoto quite well and the overall offset is mostly consistent during a mission. The offset can easily be determined using Google Earth and thus corrected. If this is possible and sufficient, ground control points are not necessarily required to provide positional accuracies < 1.5m for a directly stitched mosaic. Yet, orthophotos should be preferred. However, processing takes much longer.
Apart from some small pitch and roll offset from NADIR (calibration error) there is often some small misalignment of the camera so the images might be rotated which needs to be determined and then yaw needs to be adjusted before stitching.
4) AC3.2 „issues“
Regarding AC3.2 there are some things that need to be tackled. These are rather minor „bugs“ but might sum up to some significant offsets of single images and/or the entire mosaic or other inconsistencies:
- For consistent stitching the exact flight altitude must be known for each image. However, the „altitude“ currently used in AC3.2 is based on baro measurements. The problem is that there can/will be a drift in atmospheric pressure during the flight which can sum up to several meters over longer flights. See link for an example from a 40 min survey.
- I am not sure if this has a real influence. There is some timing jitter (missing samples) which occurs at least with both M8N (not sure about the 6H) GPS modules. Yet, an measurement offset of only 200ms might produce a considerable spatial offset especially at higher speeds. This jitter also results in some twitching.
- In addition there is some clock drift or communication latencybetween the GPS module and the Pixhawk. This can also lead to spatial offsets depending on the log file entry one relies on for geotagging.
Summary
For surveys where the highest precision is required orthophotos and ground control points are the way to go. This is also true in areas with stronger relief. However, in many cases directly stitches images georeferenced using common GPS modules are sufficient. What is required is proper geotagging and a stabilized NADIR gimbal. This involves good GPS modules as well as specific CHDK scripts, log file analysis and stitching routines. The advantage is that stitching can be processed in field within minutes, which makes it suitable for SAR missions as well as quick overviews for agricultural purposes.
To overcome some positional inaccuracies, image-matching techniques might be applied. However, there is a trade-off regarding processing time. A real boost in accuracy can be expected if RTK DGPS systems (read Piksi) are fully integrated and operational.
Any comments are welcome!
Best regards and a Happy New Year,
Thorsten
PS: A big thank-you goes to all the Ardupilot devs for all of their help and suggestions!
I would buy this Butmapping Pbotomapping today from you guys if it was avaiable... for something fast on site it looks perfect...
@Sobido, thanks for clarifying!
I am not 100% sure but as far as I know, it should not matter at all which GPS you use as GPS1 or GPS2. From the Wiki: "the flight controller will use the GPS with the higher number of satellites (Note: it will switch when one GPS has at least 2 more satellites than the other)."
The thing is that if you use both the LEA 6H as GPS1 and the NEO M8N all that will be used is the NEO M8N because it always has a higher number of satellites. That's why I switched back from two (6H + M8N) to one GPS - but the M8N.
@Thorsten
The mini drotek M8N (30x30mm), because without Usb plug ( the new XL next week will have one) , is not really suitable to be plug on a computer. For me, the Ttl/usb plug creates some perturbation on the serial port. Also, it is clear for me that the Ttl/usb is not compatible with the Tablet tru OTG ( probably consume some energy by his own) . I advice then rather to have a usb port for further post treatment.
On the pixhawk however, the Drotek, even without Usb port , works very well. I haven’t done yet enough test to put it as GPS1; may be in the next future, Need to be confident.
M8N tracker download method
1 ) From Pixhawk
or 2) from Ublox M8N itself , using U-Center
As probably already done for you too, the M8N could be positioned as GPS2 on a pixhawk.(I still keep the Lea6H as GPS1 for a while). The precision of the M8N is better for further photogrammetry treatment.
Soon the new M8L could be also another type of alternative as GPS2 to keep a straight flight even without or poor GPs! (Test to be done )
1) The Gpx feed back of the M8N Gps2 track is not so far included in Mission planner ( Unless I am wrong) .
It is not to much difficult to obtain because we could export the GPS2 Lat/lon/Alt if necessary.
2) There is also another option to note, for free :
Assuming that you can plug and unplug easily your M8N Gps to your computer, You also could simply use the Ublox Datalogger option.
In U-center the Ublox function in UBX-CFG-LOGFILTER has to be in Enabled position (and <Send> to confirm and receiver>Action>SaveConfig to confirm).
After that you will save every sec the position of your Gps.
When you want to download the past track of the GPS , Go first to UBX-CFG-Logfilter and switch the recording enabled OFF to stop the record (+ <Send> to confirm).
Then go to UBX-LOG-INFO in <Messages View> . Once here , use the Poll button and you should see your log status with entry count and so far . Chack at the end that the log recording is on NO.
You could filter with UBX-LOG-FINDTIME which is the log you need , using the timetable.Then go to Retreive to choose the first entry and entry count (+send) . Then on RETRIEVEPOS you should see the first entry.
Now if you want the correspondent Nmea file , use the tools>retrieve log . Th file you will have could be keep in Nmea+Ubx format or transform with Gpsbabel from Nmea to CSV for any further extraction.
Sobido, I am not sure if I understood you correctly when you mention the "strange and erratic data transmission". Do you think it is a problem of the Drotek M8N? Or is it a RTKLIB problem? You also mention to use it "as assistant ... as a GPS2". Hence, I am concerned about using the Drotek as GPS1. I just received one and will make some tests next week.
You're welcome. You and Thorsten are doing interesting stuff and I'm happy to help out. Also noted that the LEA4 had 2 UARTs (so I'm not crazy ;-), but the 2nd one was replaced with SPI/I2C in later models.
Bonne chance mon ami!!
Thanks Simon for the Protocol Specification of the Ublox 7 . I found the reactualize document for M8N in following :
http://www.u-blox.com/images/downloads/Product_Docs/u-bloxM8_Receiv...f .
@Simon
Sorry Simon but english is not my mother language, as you have already understood. What I have done in the test is very simple and very pragmatic :
I put the M8N on a perfect known point that we called here in France a “Geodesic Point”. You find some points like this all over the country with a perfect position in Lat/lon/Z (or local equivalence ). Then I stay, with my tablet and my M8N CSG , for 4 min , in Static position. Then I come back with my measurement. Then, a few hours after , I use a GNSS Station in the nearby city , whith again a perfect well known position, as a base for my test. I used a “RGP” French station for that and the” .o “ file of the right period that I catch from internet (1s file type) about 2 hours after my test. Then I used RTKpost with my own rover.Obs and I choose the “static” option (because I wasn ‘t moving at all during the 4 min but I didn’t want to use the “fixed” algorithm because I wanted to let him know where it is !) , with the right Lat/lon/Z of the RGP station on Positions tab.
I found here the mentioned results of lets say about 30cm with GNSS Station correction.
May be I will have still better in the future with my own base, when I will be able to have a adapted second M8N , because my second was a Drotek M8N without Usb port ( need a TTL/usb adaptor ) and it is not too much adapted for that ( doesn’t work at all for me with the tablet and delicate to parameter in RTKLIB because of strange and erratic data transmission. The Drotek module is still perfectly enough, for less than CSG, as assistant in a Pixhawk however, as a GPS2 for instance
Re-reading and not sure exactly what your 'wrong 4m distance of the true point position' actually means.
If this processed static (no reference station) then I think that it is expected. The computed position (even with good receiver/antenna) will wander around as the constellation changes, normally you'd want a long (static) occupation to average down to a true position.
It would be hard/laborious to merge the data of rover-base1, rover-base2, etc. But might allow you to rule out some inaccurate positions.
I assume that the script is just ASCII representation of the binary messages, see page 113/100:
http://www.u-blox.com/images/downloads/Product_Docs/u-blox7-V14_Rec...
Considering 'globally grouped but often at a wrong distance'; this is why I'd look at the spread of the points over the sample period. There are a few reasons why you'd have 4m offset, simplest is that the reference station/data is not at the point you think it is (did you just enter a quoted value, or process it's data as static/standalone first).
50km is quite a long baseline, we'd normally suggest <20km. If you have your own and are flying with FAA guidelines it should be really short.
I'm nerdy enough to think that it would be 'fun' to throw this data at a few different processing engines, if you're OK to share it.
2
3
4
5
6
of 9 Next
