A UAE collector upgrade still signs a camera-only clause when the interchange document never freezes height, the 4-in-1 device set, or the interoperability references. SOLARTODO LIMITED’s Berlin 28-intersection sheet already locks 6 m L-arm, dark grey, hot-dip galvanized poles that combine a 4K AI camera, 77 GHz mmWave radar, an LED fill and an LED signal, with NTCIP and GB 25280 named on the same card — enough standards language for an Abu Dhabi or Dubai collector brief, without treating the layout as a 10 m arterial gantry. This Intel community note is for traffic engineers who have to write a first 6 m 4-in-1 specification before a citywide controller refresh is scoped.
| Item | Published value |
| Scale | 28 intersections |
| Pole | 6 m L-arm steel, dark grey, hot-dip galvanized |
| Device set | 4-in-1: 4K AI camera, 77 GHz mmWave radar, LED fill, LED signal |
| Standards referenced | NTCIP; GB 25280 |
## Which standards lines belong on the first UAE card?
Keep NTCIP for device and controller communications, and GB 25280 as the signal-technical reference, on the same page as the 6 m L-arm geometry and the 4-in-1 set. If only “AI camera” is written, a later bidder can drop the 77 GHz radar and still look compliant. The Berlin sheet also describes 5G or fibre backhaul to a central platform; that path should be written as a communications requirement, not as a software brand. A BOT or zero-upfront financing line on the source page is not a technical specification and should stay off this standards card.
## What should not be substituted quietly?
An 8 m or 10 m L-arm is a different mounting class. A camera-only column without 77 GHz radar will not give the published low-visibility presence and speed support described for this 4-in-1 family. A conventional signal head without the integrated fill and camera set is a different product. Do not treat a 28-intersection count as a guaranteed UAE quantity; it is the published scale of the analogue sheet, to be resurveyed locally.
## How should a first junction sample be accepted?
Freeze height at 6 m, the 4-in-1 device set, and the NTCIP / GB 25280 language before anyone multiplies a 28-intersection programme. Keep a human in the loop for signal-plan changes. This UAE standards note may cite only SOLARTODO LIMITED’s ISO 9001:2015, ISO 14001:2015 and ISO 45001:2018 statements as factory management-system marks. No selling prices appear in this community post; commercial terms belong on a separate EXW request.
## FAQ
**Which sheet is this standards language taken from?** The Berlin 28-intersection 6 m L-arm 4-in-1 page, used as a technical analogue for UAE collector junctions.
**What are the four integrated devices?** The published 4-in-1 set is a 4K vision module, a 77 GHz radar, a fill luminaire and a signal head.
**Is a public contact or outbound address included here?** No. This community does not allow those fields. A SOLARTODO LIMITED commercial desk can issue an EXW form separately
31309170493?profile=RESIZE_710x31309170858?profile=RESIZE_710x31309170282?profile=RESIZE_710x.
