Streaming raspi camera video to Tower video widget
3689691896?profile=originalI am reporting how to stream Raspberry pi camera video to Tower video widget.
On the last weekend, I attended a drone meeting. I brought my IRIS which was given from my friend. It flew well and I was very satisfied with my first flight. In the meeting, other people brought their brand new drones like SOLO,  Phantom, and Inspire. I had a chance to fly them and I felt something was missing in my old IRIS. It was FPV! I live in Japan and because of a regulation, we can't use a 5.8GHz video transmitter without a licence. Furthermore, SOLO costs twice as in USA. However, I noticed a video widget(small screen) in Android "Tower" app and it was said that it receive custom video streaming.   In that article, the author used Ubuntu as the source. Since I had a raspberry pi 2 with pi camera, I had tried to use it as a FPV camera server. The followings are how to set up video streaming. I hope it will work with your environment.
1. Set up raspberry pi for streaming video
From the shell type the commands in the following post or clone a repo. to execute the srcript
Install gstreamer and enable hardware h264 encoding with gstreamer on the Raspberry Pi
2. Enable a camera module
Type
$ sudo raspi-config
From the menu, Select "Enable camera" and then select "Enable".
If you already did it. You can move to the next step.
3. Start streaming
$ raspivid -n -t 0 -w 640 -h 360 -fps 24 -b 6000000 -o - | gst-launch-1.0 -e -vvvv fdsrc ! h264parse ! rtph264pay pt=96 config-interval=5 ! udpsink host=192.168.3.11 port=9000
You should configure an address of the host and port. The address is the clients(an android tablet)' IP address. You can change port number. You can change the resolution of the video -w: wide -h: height. There are so many parameters to control the video format.
4. Show video on Tower widget
Please follow the instruction here.
You need to set the port number as same as the one specified above.
You only have video while connecting to your pixhawk.
Now you can watch a flight data and video footage on a same screen as the latest drones!
On Wifi network, latency was not unbearable. I hope to install a raspi on my IRIS soon.
In a future, I would like to use 4G/LTE network for telemetry and video streaming.
note: The current supply of the usb ports of a raspberry pi is limited. It is better to supply external power to wifi or 4G/LTE usb dongle or the system may hang up soon or later.
You may need to install rpicamsrc
Thanks!
  • It would be good if we could use CSI-2  (pi camera input) for HDMI 'IN'
    this is entirely possible hardware wise with multiple HDMI to CSI-2 adapter boards built around Toshiba TC358743XBG
    this will open up doors to single bidirectional ground-air link for combined RC telemetry and HD video downlink.
    right now the only piece of the puzzle missing is kernel level support for hardware based encoding/decoding. I believe that with Dronecode direct communication (request from high level developers like Trdige) to Raspberi Pi foundation is entirely doable. In fact, development platform was created by Pi foundation years ago (based on which all other boards are created), but driver development was halted and never resumed.
  • Dear Fredia.
    Thanks for your recommendation. I have not posted on your wiki. Can I make a new page or edit your page and add link to this article?
  • @Kaizu, great job with the write-up!
    Would you consider posting it on the tower wiki as well at https://github.com/DroidPlanner/Tower/wiki?
    Thanks!
    DroidPlanner/Tower
    Ground Control Station for Android Devices. Contribute to DroidPlanner/Tower development by creating an account on GitHub.
  • Thanks a lot for comments! I will try Navio soon.
  • Hi, there's no need for step 1., gstreamer-omx is available in modern raspbian.
  • Its really nice, thanks for sharing !
    Great stuff.  The video feature in Tower is one of my favourites.  Great to see practical advice on getting it going.  I suspect this would work for the NAVIO2 boards as well.
  • There's an .img file if you don't wish to go through the setup of raspberry pi (gstreamer, camera), it works with pi2/3/Zero:
    https://github.com/benb0jangles/Companion-Pi/tree/master/APMPi%20im...
    There's some guides and test experiments here:
    http://diydrones.com/group/companion_computers/forum/topics/compani...
