I have a lot of work still to do adding graphic controls and mission planning via GSM/google. Both board options have an oboard SD card, both support touch screens, both run at 100mhz from a 5 volt supply. There are some much faster 3.3v versions (with 5 serial) due later this year that will make connecivity simpler.
The instrument controls are now arranging correctly, allow you to resize and the google map is positioning (still crude). I have made an msi installer because some people have reported missing .net framework version using the .exe. Still doesn't work with the IMU but it will do over the next week or so.
As a stress test the view menu allows you to open many copies of the same controls. It seems to perform really well and has a huge amount of scope for additional controls, consoles and graphs
Down Load Windows ground Station Beta
It will be better with the mega to be able to have two way communication so that I can request the waypoints when the gcs starts up. it makes it more cumbersome to test when the waypoints are only sent at start up.
In the meantime i will use the local waypoints config file produced by the config tool. think i'll also integrate the config tool into the gcs
Yes lots of switches and dials but which, actually I would now like to chat with you about ehat each control should show, in which measurement and how to test accuracy.
I also want to open the mission config so that I can plot the mission way points on the map along with current position.
ideas appreciated
I have added a working google map locater and all controls can be expanded using mouse wheel or touch gestures. Instrument controls can be positioned but positions are not yet saved.
Attached is a windows program that will work with ArduPilot standard GCS. I am using the shield, thermopiles and EM406
For test purposes the compass shows the breaing not the heading. My first question concerns
ArduPilot standard GCS using EM406/Sirf?
Would someone mind picking up a copy of this windows ground station and tell me if you think the GPS Lon/Lat are correct.
You can see the raw values received from the ArduPilot at the bottom of the screen and a formatted value next to the map button.
If the Lon and Lat are correct then clicking the map button should show a google map at the correct location
Tim
Yes I'll get the micro version running and then look at windows version. The windows version will be easier due to more RAM and better support for Maths and Serial, the basic program structure will be almost the same..
I will make the source available form my project but you might find it easier to investigate the existing dev tools for your device.
I don't know enough about custom flavours but there are samples and an ARM version to get you going. Would the PDA would need to provide some sort of serial break out for the xbee?
After reading about the google nexus phone I'm looking for a Cortex A8 micro framework port :)
1
2
of 2 Next
