I have successfully tested the Cheerson CX-20 Auto-Pathfinder (also called the Quanum NOVA). This quadcopter uses an APM v2.52 with the ArduCopter v3.1.2 already installed. It fly very well and all the Arducopter features are working very well....
Above, a video during the maiden flight of the CX-20 has been taken with a GoPro 3 "Black Edition" mounted on the anti-jello mounting base.
Test conditions: Wind 22 Km/h gusting 33 Km/h
The APM 2.5.2 (with an external magnetometer) with the Arducopter v3.1.2 handle very well the CX-20, the flight is very stable in loiter mode in spite of the strong gusts.
Below the factory PID installed:
The flight modes set by default:
I have added a telemetry datalink and tested sucessfully the Droid Planner v2.0 (Android) and the Mission Planner (PC).
More infos at:
http://diydrones.com/profile/JeanLouisNaudin
https://github.com/jlnaudin/x-VTOLdrone
Stay tuned,
Jean-Louis
Not true just head to product page on HK (hobbyking) and in file section download the factory FW - flash and enjoy, thay also have stock parameters file that can be loaded.
read my lips, there is NO turning back, Cheerson has not released the stock fm to the public. The custom version is as good as you can get.
There is no turning back once the cx20/nova stock firmware is flashed. That said, there is a custom make 3.1 version float in cx20 discussion ghread
http://ardupilot.com/forum/viewtopic.php?f=22&t=9534#p29460
Hi Jean-Louis
A bit too bad having to speak English between native French speaking people, I presume it's due to the forum rules ;>)
Is there another place where to communicate in French?
Anyway...
After reading all what I could find about the subject and getting no applicable result, I'm sorry to bother you with my problem:
I bought a CX-20 from GeekBuyer and wanted to see what was in its FC (same as yours) before accomplishing her maiden flight; I used Mission Planner which "forced" me to update the firmware.
From that moment the things went worse and worse: no way for checking (test tab) anything; after inputting "setup" in console mode, I can only get an endless series of signs ...
Well, I tried then to re initialize the FC by loading ArduRover; all was fine with it, all tests succeeded; loaded again ArduCopter, got the same cycle of problems.
No way to arm the CX-20, though I performed compass tuning and radio calibration.
It's like if an uncompleted process was blocking the arming step.
I also tried to load the CX-20_factory.param (you uploaded), but didn't know how to do it properly.
I'm now desperate!
Any clue to solve that?
Thanks a lot in advance
JpPeretti
you can get it from Gearbest
http://www.gearbest.com/rc-quadcopters/pp_113550.html
or banggood
http://www.banggood.com/Cheerson-CX20-Opensource-Version-AutoPathfi...
hi jean-louis,
i would like to verify if you are using the ff:
firmware (https://github.com/jlnaudin/x-VTOLdrone/tree/master/Firmware)
parameters (https://github.com/jlnaudin/x-VTOLdrone/blob/master/param/CX20_PID_...)
in this post?
the reason of asking is I want to flash back the old firmware. because the 3.2.1 version which i accidentally updated using mission planner seems to have many problems, like the loiter mode)
thank you and waiting for your advise.
rgds,
ren
@Rob I hope you've figured it out already. That sounds like you got the props in wrong positions.
Currently on sale for $256.99 at BangGood, and an extra 6% off with coupon code: 15BGSF
Hello Jean-Louis, Does the Cheerson CX20 already have the APM hardware installed? If not, what kind of hardware I still needed. Thanks
@a_paolo : No, this will not affect the stabilitity in STABILIZE mode, this will affect only the LOITER, AUTO, RTL mode because the GPS is used in this case. If you have damaged the arms of the quad, I recommend you to check carefully that the level of the propeller are all well aligned (horizontal level). If one arm is a bit twisted this may create wooble and unstability.
JL
1
2
3
4
5
of 5 Next
