The 'Super Hungry Board' allows you to provide up to 8speed controllers with a maximum of 400A in total of power.
Either use the 4mm bullet plugs or the solder pads to connect the power lines of your esc to this power distribution board.
Specifications:
Amps Capable: 400
Connectors: 4mm and solder Pads
Weight: 101g (less with heat syncs removed)
Available from Hobbyking for US$ 12.88
400amps !!! are the copper layers thick enough ??
Well, there goes Power Hungry Systems business... LOL It was ridiculously priced anyway.
