Hi
I would like to ask you for little help in making this drone real, if you could support the project that would be amazing, if you cannot help financially, but you would still like to be part of it, please share the campaign!
Link to the campaign: https://www.indiegogo.com/projects/b-unstoppable-world-s-first-tank-quadcopter-drone/x/11697128#/story
Watch B-Unstoppable in action: https://www.youtube.com/watch?v=pAfy_zBL1xE
Due to our patented solution (goo.gl/c7jq5u ) B-Unstoppable achieves outstanding performance in driving across difficult terrain.
It can turn on the spot, which is extremely useful in limited space, which in turn provides 360 view from the on-board camera. As well as driving on the ground, when obstacles become too big, it can simply take-off and fly over them. The model weighs only 84 g, therefore it can be operated, without the fear of causing damage to other models or itself.
Despite the small size and low cost, B-unstoppable is packed full of great features and technology you would usually only expect on more expensive machines.
The model recently was upgraded to:
- The top end FPV system, that provides true "no latency" experience! 8 channel 4.3 inch screen, with play back function
- New 8x20 motors that increased the flight speed to 35 km/h
B
FlightBots.com
Thanks for the comment and idea.
This seems to be another idea, but having propeller inside big diameter and light wheel seems to be the one. As wheel can cope with off road terrain due to its size, also is very light on top of that gives protection to the blades.
Ex. may help with ideas around alternative drive systems
@Mielnikus I like the concept/prototype and try not to get knocked by other version(s) appearing as this stuff is moving so far just about everything is being created/done in some shape or form.
Maybe look into possible re-design(s) Ex. focusing on the 'tank idea'; if you look at your initial prototype(s) and the Qualcomm Tank Drone they both have the props exposed; consider encasing within the body and other ideas around the drive system e.g. retractable tank tank track whilst in flight//extendable when on terra firma - nice post - good luck!
@Sam. I think you are referring to the Qualcomm Tank Drone from CES https://www.youtube.com/watch?v=YaX0-zAw33s
Hi Sam
No, not yet , we are currently rising funds to begin the mass production.
Hi Ivan
The flight controller is a 6 axis gyro, it is very stable and easy to control.
This is amazing! Love it. What is the autopilot?
Aren't these already on the market?
