TBS Disco - APM mounting suggestion
3689546700?profile=originalHi guys,
Had a few queries regarding how I mounted my APM (mainly since I get a compassmot of 0%!). Well here it is. This will only work on side exit APM's!
Step 1:
Screw in  4 x 8mm risers in to the bottom plate, and add one sheet of moongel on top of the core (if you have no core, superglue some risers in the spot. Note: yes, that's moon gel stuck into the FPV camera slots.
3689546803?profile=original
Step 2:
Glue a 1mm fibre plate on top of the risers & two drops on the moon gel of the core. You can superglue the whole thing in place, but I chose to use 2 screws, for additional security. I use a battery tray plate from a spare set of quadframe legs.
3689546875?profile=original
Step 3:
Add you vibe solution. I've use moongel with good success, but I've decided to try out zeal corners (which i why I dismantled it)
3689546634?profile=original
Step 4:
Carefully place the APM in place. Take care to ensure nothing it binding; you don't want vibrations transmitted to the APM via the wires. Insert the battery to make sure it does not press the "out" servo leads. Also try and make sure the "in" servo cables don't torque the board too much, but this can be tricky.
3689546835?profile=original
Step 5:
Screw it all back together, but take not of the front starboard mount. This is where and how I placed the DJI riser. It's not exactly over the 4 holes - it only uses 2, This moves it outboard a few mm. Not much, but it might be this detail that separates a 0% compassmot from a 1%...
3689546961?profile=originalBUT...THERE'S A MASSIVE PROBLEM...
...take a look at where the USB port is.... You can still reach it with the standard USB cable, by pushing through the port front leg...but it's a really, really tricky, and you are in danger of pulling out a solder!
So find a USB cable with a 90' bend in it. And when you find one...let me know...before the logs fill up and I crash!
  • Chris & Brian, I won't be much adamant on my emphasis but would say that that were my findings. For a 550 or 600 or more size quad, external mag is really not required. Motors with large dia cause higher interference as compared with that of lower dia one's. I made my first quad at very early time when even at DIY drones, only few people were aware what Quad is.
    However I myself did so many flights with APM1 and APM2 with on-board mag and had not observed much appreciable interference till I had a serious crash during, later I came to know that my quad was fooled of direction of north and rather coming to me it moved to some other direction and crashed into the tree. After that I did so many hit and trials of different size quad frames and then finally raising the magnetometer height. For this I got inspiration from DJI however here at DIY Drones people were still using on-board mags. Reason of interference in my crash case was, one of the motor was taking comparatively high current which caused high magnetic flux.
    After raising the external mag to aprox 1 feet, I did not meet any crash due to direction fooled ;)
  • For a good magnetic interference isolation, external Mag has to be at least 30cm higher to the plane of rotating BL motors, yours seems quite low.
  • Excellent write up. I have my APM mounted in the exact same spot as you with the same problem for USB access. I ended up getting a few cheap USB cables from Monoprice. http://www.monoprice.com/products/product.asp?c_id=103&cp_id=10... This one has a small head that I can feed through the arm hole and holding the APM with one finger I can guide it in. The plan is to leave it plugged in at all times and just shorten the cable by cutting out 2 feet leaving the female end to sit on top. Its not high on my priority list, still working on PID settings.
  • Very nice setup.
    Think you could get to your USB with this?
