Techpod Drone ready-to-fly to Belize!
(Re-posted from: http://conservationdrones.org/2013/07/08/techpod-drone/)
Earlier this year, Wayne Garris from the Kickstarter projectHobbyUAV.com, donated two Techpods to ConservationDrones.org. I finally just had the time to build one up, equipped with an APM 2.5+ autopilot system.
This drone will be one of four that we will be bringing to Belize later this Summer. We are partnering with WCS to fly over Glover's reef to explore the use of drones for patrolling marine protected areas.
While building this drone, I was quite concerned about the wing flex, even though I was assured by others that these 2.5 m wings are meant to flex!
I decided to add some rigidity to the wings by fiber-glassing them with an ultra thin glass fiber cloth by applying several coats of water-based polyurethane. The fiber-glassed wings definitely helped to reduce wing flex and prevent sudden dips in the air. (I know I did not do a perfect job of it, but I am happy just as long as it flies!)
img_1118.jpg?w=580&width=750
img_1115.jpg?w=580&width=750
img_1116.jpg?w=580&width=750
After installing the APM 2.5+, receiver, telemetry and APM power module, there really wasn't much space left inside the fuselage.
img_1125.jpg?w=580&width=750
I created a battery holder using a piece of craft wood (pine), and a few pieces of velcro. This battery holder replaces the canopy, and can hold up to two 5000 mAh Turnigy batteries. The picture below also shows the location of the Turnigy Thrust 45 A ESC I used. I always prefer to place the ESC outside the fuselage to avoid overheating. The wings are held together mostly by friction at the wing joints, but further secured by several elastic bands hooked onto picture hangers on each wing. These picture hangers were glued to the wings with J-B Weld steel reinforced epoxy.
img_1112.jpg?w=800&h=597
At first, I wasn't quite sure whether to glue the nose dome to the fuselage. In the end, I decided to improvise a hinge using control horns so that I can access the APM and receiver from the nose if needed.
img_1119.jpg?w=800
The motor mount was given extra support from two 5 mm diameter wooden rods wrapped in shrink tubes, taped to the rear of the fuselage and zip-tied to the motor mount. I used a Turnigy 3536 1000 kv motor spinning a 11x7 2-bladed MasterAirscrew propeller. This combination provided about 1.6 kg of thrust, drawing about 30 A at 100% throttle. The All-Up-Weight (AUW) of this setup with one 5000 mAh battery is about 2.0 kg. This plane can cruise comfortably at 30-40% throttle drawing about 6-8 A. (I fly it with about 5 degrees flaps, which significantly improves lift without creating too much drag.)
img_1114.jpg?w=800
The rudder servo was moved from underneath the fuselage to nearer the tail section. I used 22 g Corona digital metal gear servos for the rudder and elevator, and 11 g Turnigy metal gear servos for ailerons and flaps.
img_1121.jpg?w=800
I don't like fussing with aileron and flap connectors inside the limited fuselage space, and so decided to bring them outside. This makes wing assembly and disassembly in the field much easier. In this picture you can also see the antenna for the 3DR telemetry.
img_1129.jpg?w=800
I installed front landing gear to a piece of plywood Gorilla-glued to the bottom of the fuselage (where the carbon fiber rod is exposed).
img_1103.jpg?w=580&width=750
The rear landing gear was screwed to the bottom of the tail section. These two screws also attach the vertical stabilizer to the carbon fiber rod.
img_1101.jpg?w=580&width=750
The horizontal stabilizer is attached to the vertical stabilizer by an improvised system of control horns and 1.5 mm carbon fiber rod. These mods make the Techpod completely modular and can be easily disassembled and packed back into its shipping box.
img_1104.jpg?w=580&width=750
I improvised a camera mount by just attaching a 15 mm diameter carbon fiber rod to the main carbon fiber rod using a few pieces of zip-ties (cable ties). This system also allows me to adjust weight distribution to achieve optimal CG (85-90 mm from leading edge of wings).
img_1132.jpg?w=580&width=750
img_1133.jpg?w=580&width=750
img_1136.jpg?w=580&width=750
img_1134.jpg?w=580&width=750
During the maiden flight, I tested flight endurance by letting it fly in Return-To-Launch (RTL) mode. It did so mostly at a speed of 10-12 m/s at 30-40% throttle. At 50% battery capacity (of a single 5000 mAh battery) it had stayed in the air for about 18 minutes. So I estimate a flight time of 30 minutes (range of 21 km) with one battery and 50 minutes (36 km) with two batteries.
... Sneak Peek of the next Conservation Drone, based on the amphibious Icon A5!
img_1138.jpg?w=800
  • Got a response from W. Garris on the question of the the TechPod's center of gravity. He says "On the spar is neutral. 1/4 to 1/3 MAC (root cord is MAC* ) is normal."
    I don't have my TechPod to measure the wing chord, so I'm not sure where that places the CG in mm but in any case it's enough to go by.
    *Mean Aerodynamic Chord
  • Looks great! All the mods are really interesting.
    Out of curiosity, where did you get the 85-90mm C.G. range? http://diydrones.ning.com/profiles/blogs/my-techpod-nears-completio... suggests that it's at the center spar, which according to my calipers is approx. 69mm away from the leading edge.
    By the way, for those looking for a nose cone idea, I took a 2L soda bottle and cut off the top. It's held on by a rubber band attached to the inside of the cap and hooking onto the rear wood platform. This solution works really well, and with the help of some washers mounted on the tip of the cone I'm able to trim the C.G. to exactly where I want it. The extra space helps me slide the batteries far forward when I'm not flying any equipment. This was useful for my test flights because I keep the weight of the plane down with the smaller battery.
    3692793054?profile=original
  • Thanks Martín!
  • they dont recommend water based polyurethane on paper covered foam. You must be carreful with coatings direct on foam.... your wing may disapear...
  • Thank you for sharing. Great stuff! FYI, I watched this from Flitetest and they don't recommend the water-based polyurethane, haven't tried it yet here, but will do soon as I'm also finishing up my TechPod! https://www.youtube.com/watch?v=vgBrB3IK-i8 a
  • 100KM
    Nice build. Love all the mods.
  • Watch out for orientation of your 3DR radio. That antenna should be pointed up or down unless you're going to only be flying straight overhead! As it is now, you'll have a big null out each wing tip.
  • It's great to hear about your work with WCS to explore patrolling Glover's Reef. That is a beautiful area of the world.
  • @John: I ditched the dome and carved foam to close it up. The dome would easily break on hard landings and this way it's more resistant. The camera goes in under front, the standard hatch is closed up to create battery space. The only way I found to make effective use of the hatch is to load batteries over the camera, making access complicated.
    Another option would be to strap the cam under the wings, but that felt stupid for a pod this size.
    I've also created more distance between receiver equipment and transmission equipment then in these pics. Telemetry rx/tx is way up front on the nose, the rx and gps are on a wing, away from noisy electronics like the ESC or AP or the camera. The AP is isolated from the noisy camera ground through an opto-isolator with a separate 2S.
    It would be great if the space under the wings could be exploited more, so that the CG doesn't move forward too much on heavier loads.
  • A GoPro for aerial surveying?   seems pretty expensive considering the types of cameras that don't fisheye every picture and that are readily available on craigslist / email sort of places.
