Here is what you get
including :
EPP wings and tail , carbon fiber tail boom , CF wing spars , CF joiner , CF tail spars , CNC cut aircraft grade plywood , polycarbonate front and rear lids , 1/4 turn fastener for front lid , acrylic camera dome , ABS molded engine cowl , all push rods , control horns , balsa sheeting and stock , all needed screws and assorted hardware .
Not included but recommended running gear
motor : E-flight power 10 brushless in runner
ESC : castle creation thunderbird-54
Batteries : thunderpower pro light v2 3S 2600 mah x2 wired parallel
servos : 2x hitec HS-81 (elevator,rudder) 2x hitec HS-55(2x ailerons) 2x HS-5055mg (pan,tilt)
TX & RX Spectrum DX-7
Prop : APC E11x7
camera : CCD Killer Camera Micro NTSC Camera
as of this posting there are only 4 left from this run . the material for 20 more is on the way . will be available in approximately 2 weeks
for the latest news check http://evuas.com
We sure can although I would suggest a traditional mold or 30# density tooling board cut on a 3axis router. The cost of aluminum molds is outrageous. Its mostly due to the milling time. It cost a bit to run that big machine each hr.
Anyhow the offer is on the table. I will build you a traditional mold for "free" and may be open to cutting one from tooling board on our machine. You can e-mail me at chris@attopilotinternational.com.
send me personal message .
@ Chris
can you make aluminum molds ?
video here :http://diydrones.com/video/techpod10-remzibi-osd
what do you mean by durability ? this is meant for hobby purposes , I have not done any extraneous cycle testing . I have flown 1 model for 40+ hours with no problems .
