Tersus GeoBee - Cost effective CORS solution
3689737077?profile=original
Ntrip server mode: use David GNSS receiver to create a base station. This temporary base or CORS are for surveying, agriculture, UAV, machine control, and so on. It is also ideal for deformation monitoring.
The Tersus GeoBee is a dedicated and cost-effective solution to transmit or receive Ntrip corrections. With Tersus Ntrip Caster Service, Ntrip Modem and David Receiver, the GeoBee opens the possibility for users to transmit Real Time Kinematic (RTK) corrections via Internet (Ethernet or 2G/3G/4G) in a simple, user-friendly way, just using a SIM card or Ethernet cable without any need of a static IP. GeoBee can also work as GNSS Rover to receive RTK corrections from Tersus Ntrip Caster or any CORS service.
3689737099?profile=original
Ntrip client mode: connect David or other Tersus GNSS receivers to Tersus Ntrip Caster or any Ntrip/CORS service.David is mainly used for surveying, and also used as a GNSS sensor in various applications, such as mobile mapping,UAV, machine control, agriculture,etc.
3689737108?profile=original
Features,
  • Supports multiple constellations & frequencies(GPS L1/L2,GLONASS L1/L2,BeiDou B1/B2)
  • Support 384 channels
  • Supports RTCM2.3/3.x, CMR, CMR+ corrections
  • Supports 4GB internal storage
  • Rapid RTK integer ambiguity resolution
  • Supports stable, high-precision measurement output
  • Supports Ethernet is default while 2G/3G/4G is hot standby
  • Supports remote access and operation
GeoBee is a low cost CORS solution for customers worldwide. It is widely used in Land surveying, machine control, high precision agriculture,UAV application, and so on.
Please contact us for more detailed information if you have interests in our solution or becoming our dealers. Thank you.
Website: www.tersus-gnss.com
Email: yunxia.hu@tersus-gnss.com
