Testing Arducopter using a bench power supply
3689491191?profile=originalI'm starting to build my Arducopter and immediately after having gone through the tests I could do with Mission Planner and a USB only I started looking for a solution on how to avoid recharging LiPo batteries every 10 minutes of testing, a especially how to avoid spending money on replacing AA stilo batteries just for testing the radio.
So I came with the idea of using my bench power supply for powering both the Arducopter and the radio. I basically created 2 power cables, one that goes into the battery socket and one that goes into the radio power plug: on one side the respective plugs and sockets (a JST connector for the radio and a XT60 connector for the battery) and on the other side two banana plugs that go into the power supply.
I doubt I'm the first using this approach for testing, but I don't recall seeing it anywhere, so I thought it was worth posting it.
Here more pictures of the setup.
A closeup of the TX power cable
test-power-cable.jpg?w=1400&h=A close up of longer cable plugged into the TX
3689491250?profile=original
 A close up of the other cable, plugged into the battery socket
3689491281?profile=original
I'm documenting my build process on my Drone and ROV related blog, so if you are interested you can also have a look at it to see how I am progressing.
  • how many amps and volts are you setting bench power supply at?
  • Ibrahim, the best solution is to buy a ready made kit, like jDrones or the 3DR kits. It cost less and it's less time consuming than buying all the pieces separately. The links to buy them are in the menu of the site.
  • Yeah, I know, have to find some first :)
    Thank you
    Simone
    I would recommend using a 2 cell balancer JST plug as it has the correct number of connections (3) meaning you are less likely to plug it in wrong into the radio the. With two connections you can plug it in reverse on the connector and destroy the radio.
  • Dear Simone, would you please give me a list of components to build a quad-copter...I need a recommended list of components since it is my first time to build it. I am so appreciated... Ibrahim (ibrahimabdelhameed@yahoo.com)
  • 3692566712?profile=original
    3692566611?profile=original
    3692566584?profile=original
    3692566727?profile=original
    3692566759?profile=original
    3692566774?profile=original
  • I use a power source for security cameras 20 amp 275 watt, this method to calibrate and test the quad is a source of economic and 6 amp 12 volt for the radio is very good. with a 12 gauge wire two pairs of 2.30 meters long I can last for 24 hours at half throttle and 16amp with 8 engines.
