I know that gimbals are really cool and make great things possible, but I just can't wait for them to die. They are heavy, draggy and add complexity. It would be great to just record everything and then scroll to the portion on video you want to see. If you are capturing video for a production, you can fix it in post. If you are doing surveillance, you could completely stabilize your view with software. Maybe this will get us one step closer:
http://bit.ly/1gV7n2c
Thanks Joe! Very cool!
https://www.kickstarter.com/projects/1307511016/centr-interactive-p...
@R_Lefebvre:
The closest thing available to hobbyists is the Panono, but it currently only takes stills. I can't imagine the CPU that can capture video at 108 megapixels and still launch in my Bixler.
Rob - Yeah, his type of camera really needs a Curvilinear Image Sensor.
But as you say John, low noise, high contrast and low light performance calls for more glass and a larger sensor with bigger photo buckets/diodes.
What if they make a spherical imager chip? Wouldn't that solve the problem of fisheye lenses? Thing is in that case... I'm not sure how a lens would work, to focus light on the chip.
Then instead of that, an array of non-fisheye lenses, and flat chips. With overlapping viewing angles. Then you combine them in software, and allow the user to pick the framing from the combined image.
Joe, as always price is the biggest decider. You can make incredibly sharp lenses, but they quickly become bulky and typically cost more then your entire copter system. Same with high resolution sensors. More pixels means more processing, thermal challenges etc. adding cost at every step.
Carles, that is the nature of any fisheye lens. To be precise, the actual lens can have great optical sharpness at the edges, but the areas that the sensor has to cover gets larger and larger as you get closer to the lens edge. Meaning that the spatial image resolution is much lower at the edges compared to the center.
John, you say that the fish eye 360 deg are only sharp on the center. What makes you think so?
I believe that this is the future of gimbals, simpler, light, cheaper than gimbals, and requires much less prossesing power than camera arrays.
1
2
of 2 Next
