Hello to All,
I have done successfully the first test flight of the Quad Rotor Observer (QRO) v4 with a new costless flight controller board V7 which uses a Atmega 168 and 3 piezo gyroscopes (NEC CG-L43). This is a personnal variant of on the KKmulticopter board widely spread on the web. I am really surprised by the stability and the flight enveloppe of this quadcopter Vs the simplicity of the firmware code (Occam's razor principle...) and the low cost of the electronic material used here in this design...
Tested setup:
- personnal flight controller v7 with Atmega168 and 3 piezo gyro CG-L43 based on the KKmulticopter board
- firmware Quadcontroller v4.5 by Rolf R Bakke
- 4 brushless motors DualSky XM2822CA 1450KV 7A
- Lipo battery 3S (11.1V) 1500 mAh
- receiver Corona CR6D 2.4 Ghz
More technical infos at: http://diydrones.com/profile/JeanLouisNaudin
  • I request you my dear friend .can you please help me to read the PWM signals from the receiver and write them through the microcontroller to the ESC
    my website: http://www.quadrotor.co.nr
  • What is your landing gear made of?
  • From where you got CG-L43 ?
    Hello Jason,
    If you see the firmware code, when the throttle is set to 0 (<5%) the gyro are recalibrated... So, each landing the gyro are re-calibrated... see below:
    ma82:
     ;--- Calibrate gyro when collective below 1% ---
     lds t,FlagCollectiveZero
     tst t
     brne ma12     ;collective below 1% ?
     rjmp ma4
    ma12: lds t,CalibrationDelayCounter   ;yes, increase delay counter
     inc t
     breq ma50     ;delay reached 256?
     sts CalibrationDelayCounter,t   ;no, skip calibration.
     rjmp ma51
    ma50: b16clr GyroZeroRoll    ;yes, set gyro zero value (average of 16 readings)
     b16clr GyroZeroPitch
     b16clr GyroZeroYaw
     ldi counterl,16
    ma20: rcall ReadGyros
     b16add GyroZeroRoll, GyroRoll
     b16add GyroZeroPitch, GyroPitch
     b16add GyroZeroYaw, GyroYaw
    Regards, Jean-Louis
    Well, you'd be the first to try it. Anyway, wonderful as usual.
    You could also include a reset switch to zero out the drift in flight... I did something similar using a training switch.
    Jason
    Hello, I have just conducted a Power/Weight ratio measurement with a DPR-50 datalogger on board of the QRO v4 during a stable hoovering at 2 meters above the ground.
    The Take Off weight (with the DPR) was 668 g
    The Average Power required for the hovering was 95.29 Watts
    So, this gives a Power/Weight ratio = 143 Watts/Kg
    3692147465?profile=original
    Regards, Jean-Louis
    Hello Jason, Yes, why not... but at this moment the firmware works very well as you may see in the video of the flights and the drift time is greater than the flight time (about 5 min)    ;-)
    Occam's Razor principle can be applied here...
    Why not use the feedback from the user to correct for errors? If the user is sending commands to right the ship, you could use those to slowly correct for drift. If the gyro drift is not too bad that is. Maybe limit the integration to commands of 5 deg or less.
    Hello Jhon, This is fully indicated at the end of my QRO video...
  • song name? :P
