If you are using MegapirateNG and a Crius AIOP board with the Turnigy 9x, as you will be aware, the standard 9x receiver doesn't enable the somewhat important throttle failsafe feature in Arducopter & Mission Planner. This is due to the AIOP board not having a PPM encoder like the Ardupilot board. I say important, because in the event the turnigy 9x loses power, and then regains power, It will not be in control of the quadcopter anymore. Which can be a bad thing indeed.
However, I have the Throttle failsafe working on my 'Locust Quadcopter' AIOP board, using the standard 9x receiver (9x8cV2).
It appears to have allowed me not to purchase the Frsky modules (£50/pair?) just to enable throttle failsafe.
If you would like to try it, I have used this cheap PPM encoder V1 board which cost me just over £4 on ebay.
It was quite simple:
I set up MegapirateNG on the Arduino software to enable the default PPM (Changing it from my previous PWM signal), and uploaded it.
I then plugged the ppm encoder board between the 9x receiver and AIOP, sending the 3 ppm wires (+5v, GND, PPM) to the AIOP board (+5v, GND, A8).
I powered the 9x receiver from the AIOP board also (powering using the PPM encoder board didn't work for me). I didn't use the MUX wire on the PPM encoder either. It's not necessary.
Then, it was just a case of connecting the ch pins from 9x receiver to PPM encoder as you see fit for your needs.
I didn't have to modify the PPM encoder at all. It worked as it came, out of the bag.
If anyone wants assistance I'm happy to offer advice.
how to:
