TIP - Using the fragile micro USB connector on the APM
The micro USB connector on the APM boards is extremely fragile and easily damaged.
My solution was to insert a Micro USB to Mini USB adapter to the copter:
3689479014?profile=originalThis way, I just use any Mini USB while on the ground or bench, and leave the adapter cable on the copter.
Here's an example:
Female-Micro-Adapter-Cable
Do not try to use a similar appearing charger adapter.  They typically lack the data wires.
On the other hand, I do use a USB charger to power the APM without connecting the LiPo.  This lets me safely communicate with the APM over the 3DRadio.
  • And, what about vibrations? the cable could transmit from arm to APM directly.
  • That's a great tip. I always feel like I'm going to break my APM connector when I plug it in. I'll definitely be doing this. Thanks.
