I have been moving forward with my project to build a transverse rotor UAV. Here is a quick overview of this Bell-Hiller concept. (Oh, btw this is only a quick sketch done in Google Sketchup, it isn't totally to scale nor have I drawn in the entire structure)
1) Single brushless motor will drive conter-rotating rotors
2) CCPM swash plate will provide additional level of control including roll-control w/o gyroscopic affects.
3) I am using a Bell-Hiller mixing instead of mounting rotors directly to motors (no swash or flybar) and using large servos to control pitch and roll. This will allow for added inherent stability, and I will be able to use much smaller servos
Next step is to verify this design with the community (you), decide how much I can buy off the shelf vs how much I need to build myself, and then start building and working on the electronics portion. As soon as I know how many servos/sensors I'll need, I'll choose a microcontroller and start that parallel project. Stay tuned, I've told too many people about this project to give up now... :-)
I'm using flybars because I fear that as I shrink this platform, it will require very sensitive servos and high i/o bandwidth sensors to stay autonomously stable. I have a blade msr and I was thinking of maybe modifying a set of msr rotor heads to ccpm.
Add a basic 3axis accelerometer under each prop, a digital compass and gyroscope for stabilization, and many long nights programming, and I think I can make this a rather stable sub micro VTOL. I'm not sure I want to rely on sensors for the whole route.
thanks for the advice guys, I agree this is a major project! I hope to do it right the first time...so keep your comments coming I appreciate it. I'll be sure to share the progress I make.
