    Mike, I'm shooting continuous video at the moment from launch of the plane. However, the software does support a trigger signal to a servo from within the waypoints definition file. The camera servos are being driven by the Direction Cosing Matrix, which is rotating the vector of a ground based target (Earth reference) into the direction of the target in relation to the plane's orientation (Plane Reference), and then calculating the servo deflection. This is being done 40 times / second as part of the main routines that read the gyros information and keep the plane stabilized. The code is all published as part of MatrixPilot. See here for MatrixPilot camera code.
    The pitch and roll gyros are corrected for drift using the gravity vector obtained from accelerometers (which in turn are corrected for forward acceleration and centripetal force). The yaw gyros are usually corrected for drift using the GPS velocity vector. However, nowadays we also automatically calculate the wind, so we then obtain the true heading of the plane from the GPS velocity vector corrected for wind. We can optionally fit a magnetometer, which can then also be used to correct the yaw gyro drift. This has the advantage that the yaw gyro is then correct before take off, and so autonomous take offs are then possible. Best wishes, Pete (Off to do some flying).
  • Just tried cinellera for the first time this week. Played around with the motion filter. Cool stuff!
  • Also, with dead reckoning working now, the camera will retarget 40 times per second instead of just 1-4.
    Bryan, I spent some time re-writing flan.pyw and so have not been doing any further camera work for now. Essentially the software works. We also have a new maths library which can make the maths and gyro more accurate. The main issues for me are around a) having a better camera in the plane, b) improving the accuracy of the pan servo.
  • hey pete - any updates on your targeting efforts?
  • Congrats Pete, on the camera targeting code. Thanks also for posting the link to Cinelerra, I'm going to have to see if I can get it working on my Mac :).
    @Curt. That is a really interesting library. Thanks for point it out. I think there are much more exciting things to think about. We now have 30 frames / second of HD Video, where the camera knows it position to within 2-3meters and potentially it's orientation in 3D to within a couple of degrees (and possibly 0.5 degrees soon).
    So can we start to do image analysis and build a 3D view of the world ? Both for improved mapping, but also potentially improved navigation ? May be we would need software stabilization as the first module in that process, before passing the pictures on for further analysis. This mean each frame would have more accurate orientation information when it is parsed onto the 3D feature extraction process.
  • I've been toying around with some ideas for doing real time digital stabilization in software using OpenCV ... but so far only pondering some different ideas in my head. I wonder if I managed to put something together if this would be of any interest to the hobby uav community or perhaps there are already enough products available to do this sort of thing that I shouldn't even waste my time.
    Well, to be accurate there are three layers of stabilization. UAV DevBoard stabilizing the plane. UAV DevBoard stabilizing and targeting the camera, and post-flight software stabilization of the picture.
    @Curt. There are two levels of stabilzation. The plane does it's best using the on board gyros in the UAV DevBoard to stabilize as well as target the camera. Then, post-flight and at home, I run the software stabilization over the parts of the video where it makes sense. On an IBM ThinkPad T60 laptop that takes about 20 minutes to re-render the entire video as background task. The video is about 2 minutes long. So it is very CPU intensive process.
    I expect to make the Gyro stabilization better, but will probably always add some post-production software stabilization when presenting the video on-line.
