UAV flight in the rain, automatic landing on the airstrip from Krzysztof Bosak on Vimeo.
This time a flight in the rain.Should be a part of 'National UAV Mission Readiness Enhancement Programme'.If there would be any development.Note a few details:-Landing along the 'runway', fully automatic-Nice agreement with preflight mission simulation-No dramatic events due to rain thanks to IMU sensor-Low-tech video reception, almost a trademark. Sorry, my focus is not FPV, but fully autonomous photoshooting-Roll stabilisation failed because the pitot tube got water in it, lowering perceived airspeed and diverging roll angle. Using standard servo didnt helped - 45deg/s is not enough.You need to be a member of diydrones to add comments!
The buildup of water was not dramatic as the underside of the fuselage clearly shows advanced water drain system using patented porous materials Made in Germany.
The autopilot flew as you see it and I must say putting a foam under it was a good idea: after a hazardous flight, the System Operator might be sweating and a wet sponge would be very handy in those circumstances.
To be fair, today's flight preps ended the operations quick: the sponge got very wet after the first landing in manual mode, shorted sensors voltage regulator and the Ready LED reported IMU malfunction, requiring drying it. It works fine but the sponge must go. It would be clever to cover the autopilot bay but the reason of not doing so is that I wanted to test the barometer response so I replicated conditions from good weather.
The regular EasyUAV has nearly rainproof (not fully waterproof) sealing using dense foam - what I am really testing here are technologies from 'Careless Systems Intl'.
the esc is simply wrapped by fiberglass scotch.
surprisingly this worked for total 40min in the rain build upon 2 flights, plus one short landing demo.
Brian
-the plan was to stay at home when it rains. It requires really solid navigation system
-EasyUAV is intended to be used even without groundstation, but the weather might change when returning from long range flight. Instead of making 100 flights in mild rain, I prefer to make 20 in heaviest rain possible.
-I was afraid that the humidity will affect this specific pressure sensor readings too much. It wasn't the case.
-Also, thermopile-based autopilots are known from having problems among clouds. Reliability makes a difference but must be demonstrated,
There is an option using temp compensation output of analog gyros, but those make a bulky 3D setup (FLEXIPILOT is flat except servo output pins and I prefer keep it that way, even resigning from airspeed sensor).
