Ultra Reliable Switch Test with EDF motor
Hi Guys,
Maybe you know, i'm designing FPV electronics but this product not for FPV :)
We are sharing same flight field with gliders,glow and electric planes and most important problems was switches for everyone.
This is why we designed this small circuits
Standard slider type switches are the most important crash reason on glow planes/gliders and they can affect from vibration, dust, oil and moisture.
Ultra Reliable Switch works when only slider switch mechanical off, and you are forcing to close it when switch on. This electronic design uses high power MOSFET for opening the switch and current limit is extremely higher than all mechanical switches.
We are using 20Ah MOSFETs for this small switches and they can handle 100Ah peak currents on hard conditions.
You can use it with your Gliders, Glow planes or Small EP planes.
Features
  • Low Quiescent Current (50uA on 5Volt)
  • Very Low Internal Resistance (0.006 Ohm on 5V)
  • Wide Operation Voltage (2-30Volt)
  • Very High Current Resistance (20A Continuous, 100A Pulsed)
  • Onboard LED indicator
  • Large Soldering Pads
Usages
  • Receiver battery switching for Glow and Gliders
  • Ignition system switch for Fuel Engines
  • LiPO switch for small EP planes (20A Max)
  • Safe Switch for other hobby electronics
  • Mehli, still do not understand, maybe if you explain how you would operate this switch it would help ? How do you set it to closed/open etc.
  • It's closing circuit when slider switch mechanical off ;)
    You cant close a slider with vibration or other unwanted reason, but you can open it easily with vibration when closed. Ultra Reliable Switch using slider for checking open position. You can change this slider with any switch, current drawing over mosfet, not on slider.
    It is useful for making remove before flight type switch :)
