3689428530?profile=original
This is an update from the original blog post in October 2011:
I've updated the Ardustation 2  source code to allow compilation with Arduino 1.0 Relax and the latest libraries for ACM 2.5.3 and APM 2.3.0. This update also includes a modification of parameter names for PID editing that match ACM and APM. The updated version is 2.0.12.
The download zip file also includes the libraries used to verify compilation of the software. The software has been lightly tested with ACM and 2.5.3 and has not been tested with APM 2.3.0.  If you find any issues feel free to comment here or post an issue at the Ardustation 2 Google
The software is available here:
http://code.google.com/p/ardustation-ii/downloads/list
Download 2.0.12 for ACM 2.5.3 or APM 2.3.0 - compile with Arduino 1.0 Relax
Download 2.0.11 for ACM 2.0.48 or APM 2.24 - compile with Arduino 0022 Relax
Heino R. Pull
The original 10/2011 info follows:
With the help of Jeff E and Hai Tran, I've updated the Ardustation 2 Antenna tracker code to support the detection of the UAV platform from the Mavlink heartbeat. Parameter download and editing is automatically configured for ArduPilot 2.24 or ArduCopter 2.0.48 when Mavlink connects. The key parameters available for editing is modifiable in the source code with the  PID gains set as the default for both platforms. A number of bug fixes have been made to previous versions of Ardustation 2 including a more standard Mavlink interface for the latest libraries distributed with APM 2.24 and ACM 2.0.48.
This version has been ground tested with APM 2.24 and ACM 2.0.48 with parameter editing, but testing is still needed to verify that the appropriate parameters are changed correctly. Please be cautious if you try this software out and verify the parameter changes with the Mission Planner.  I don't have a fixed wing setup to test APM in the air, but I plan to test ACM 2.0.48 while tuning my loiter values on my quad this week. I've included the libraries used to compile the code in the zip file.
A video describing the original antenna tracking functionality is available here: Original Ardustation 2 Antenna Tracker Post and Video
The updated code is available here: Ardustation 2 ACM/APM Version 2.0.11
This software is based on Phillip Anthony Smith's Mavlink Ardustation. Thanks also to Jeff E and Hai Tran for their code additions and suggestions.
  • Helldesk - Heino is correct. (I've looked at that too) The low end Atmega 168/328's that are found in first generation Arduinos have only one uart-based serial port capable of the 57600 baud rate. That port is commected to the USB interface and so there's no second high-speed port to talk to the airplane.   I've tried using an Ethernet Shield to create a second high-speed port since Mission Planner does offer the option to use either TCP or UDP in addition to com: ports.  My starting code is pretty simple and the results so far are unimpressive.
    I'm beginning to move towards using the Arduino Mega or APM boards together with a "ground station shield".  The Mega's 1280/2560 chips have four uart ports with one dedicated to USB.  The XBee would have a uart port, with two left over for a gps and maybe a second XBee on 2.4ghz.  This approach puts the antenna tracker inline between the telemetry XBee and the ground station.  All Mavlink packets are passed through in both directions and the airplane data packets are used to aim the antennas.  The tracker uses position/home data from the airplane and is not dependent on the user's choice of ground station software.  The ground control software is no longer tasked with real-time antenna tracking.  Heine's current ArduStation software could be adapted for a Mega-based platform.
    Heine - I checked my XBee docs and found that they do have a broadcast protocol.  Mine have always been pairs so I wasn't familiar with that mode.  To set them into broadcast, they must have the same PAN id number and the same RF channel number.  Then the upper remote address is set to 0xFFFF and the lower remote address is set to 0x0000.  They will then implement a data "party line" where every XBee in range will decode and deliver every good packet it hears.  I'm going to test this out with my 900mhz pair today and will posy the results.
  • That is something I haven't thought of but is an interesting idea. I've traced the full set of Mavlink packets when the Mission Planner is on the HUD display and it is quite a bit of traffic - particularly for the higher rate messages. Also the Atmega 328 only has one hardware serial port so that limits what you can do at 57600 baud plus there isn't a lot of ram for buffering messages. But with the Apm 1280 it would be very doable. I know there are others working on more advanced Ardustations with 1280s or better and this would be something to look at. The poor Atmega 328 is definitely a struggle for coding functionality when Mavlink is involved.
  • Andy - That is a great question. I was very expedient 4 or 5 months ago when I wondered how I could get antenna tracking working while the Mission Planner was up on an Xbee and I searched and searched Google for what happens when more than 2 were up and running. I found a post - that I can't find right now that made it clear that in general it would be possible to have 3 and that they would mirror each other. I tried it and it seemed to work pretty well with default settings in XCTU with the same PAN ID for each module.  I also looked at the serial messages with my logic analyzer and the messages were intact with no interference that I could see. Since the parameter request mechanism only happens rarely, it semed that collisions would be a minor problem and when it seemed to work I stopped investigating.
    Now that you asked I'm very curious myself and did some hunting tonight in the docs. It is definitely broadcast mode and the key (I think) is that when an Xbee sees received RF data, it holds back the transmit buffer until the received packet is finished. The transmit buffers are sent after 3 character times of no serial data. So it seems in general a burst of serial data representing a Mavlink packet is held together (since they're pretty small for the ones I'm sending - Mavlink on, Mavlink off, write parameter, and get list of parameters). Therefore, if two Xbees transmit a request for parameters near to each other, unless they exactly transmittling the full packet at the same time, one wins and blocks the other while the a/c Xbee receives the command.  Yesterday when I was testing I did a scenario like that and watched the Mavlink request parameter list packet in the data stream within a few seconds of each other and saw a complete packet request from both ground Xbees. I'm sure there will be cases when two xbees will transmit RF exactly on top of each other and then I don't know and iin general I wouldn't want to create some kind of "network" in this mode, but for the case of two ground stations, it seems it will work pretty well.
    I'm frustrated though that there doesn't seem to be much info on the RF protocol for the proprietary XBEE 900 Pro long range protocol.
    You're definitely a much more advance Xbee user than I am, but I definitely needed to understand a little more about what's making them tick.  I'm still searching for more detail but they are really cool devices.
    The other thing I realize now is that trying to wire two ground Xbee serial transmit lines together would be really problematic since there would be no mechanism to hold a Mavlink packet together and it would be likely to clobber bytes to the a/c when two request parameter packets would be close to each other. The Xbees make this "or"ing more feasible.
  • Heino,
    In my XBee setup, the two radios use each other's hardware address as a way to establish a "pair".  They connect with each other on power-up and implement an ARQ protocol to pass data.  I haven't seen a two-to-one XBee setup yet and am scratching my head as to how the X-CTU setup would be done.  Is this more of a broadcast mode, like the difference between TCP and UDP?  Enquiring minds would like to know ;-)
  • Andy and Mauricio: The easiest way to run a computer with Mission Planner and an Ardustation is to use a total of 3 Xbees. One in the aircraft and then one for the PC and one for the Ardustation.  If all Xbees are on the same channel, they will "or" the data to the software in the aircraft automatically. Unfotunately, when working with parameters both the Mission Planner and the Ardustation will make requests on the transmit serial line for the aircraft to download the parameter values. Two xbees on the ground handle it pretty well.  It would be possible to use one Xbee on the ground but since the AS and MP need to independently send the command to download parameters, you would need to wire together the transmit lines from the computer and the Ardustation. This requires some kind of "or"ing of the signals such as an open collector arrangement with a pullup or a logic gate. Using an extra Xbee makes it all very simple at the expense of an extra Xbee.
    The Ardustation software only looks for parameter packets if it has been requested by hitting the menu selection so that is what adds the complication.
    The patch antenna is indeed for FPV and I originally only used the antenna tracker function and ignored the parameter edit ability in my use.  However there were enough requests from users who wanted to also edit parameters - so the parameter edit function was updated to both APM and ACM parameter types. If the Ardustation is sitting on a moving antenna, it is awkward to try to use the buttons and display so that is why it is nice to be able to use the Ardustation for antenna tracking only and to simultaneously use a computer with Mission Planner for parameter editing.
  • Hi Heino,
    Excellent work. You can use the ardustation and the Mission Planner with PC at the same time? Also, there are a thing that I don't understand, and is why you need to use the Xbee and the Patch antenna? The patch antenna is for FPV?
    Thanks,
    Mauricio
  • Heino,  Thanks for doing this!  Can you please explain how Ardustation would be set up if I am already using APM Planner with a 900 mhz XBee running at 57600 baud?  Does A/S just monitor the data stream?  Could it be placed inline with Mission Planner where it communicates with the airplane while listening to the downlink for the appropriate Mavlink packets?
    Thanks,
    Andy
  • Hi Colin - it sure is hard to know what others are working on the site  but I'm definitely interested in what you're doing. We should definitely compare notes and I'll check out your code also.
  • Nice work. I just had a play with this and it’s looking good. It’s a shame I spent the last couple of weeks doing very similar work.
    I have been updating my version of Michael Smith’s Ardustation code (which used BinComm). It’s working fairly well now, with flight data and parameter editing (no antenna tracking). I’ll be ready to share it in a few days time- maybe we can “compare notes” so to speak.
  • Looks very good! Well done!
