Hi Everyone,This is last project of this year :DI designed USB to PPM generator, this device generating PPM signals like TrainerBox for your Transmitter.This mean, you can fly with your PC joystick or your own software based autopilot(if you can develope your software)This is my test joystickimg_0236.jpgThis is USB PPM generator device's insideimg_0237.jpgThis is genrated 9 channel positive PPM signal(it can generate negative also)img_0238.jpgAnd this is finished product's outside. It is similar size with USB stick and including 1.5 meter cable for your transmitter. I will sell it with compatible plugs for Futaba,Hitec, Jr, Multiplex, Sanwa, Airtronics, ESky.img_0239.jpgFeatures;
  • DirectX Based Joystick interface
  • 9 channel PPM generator with compatible all RC Transmitters
  • Cunfigurable PC based driver software for all joysticks or keyboard features.
  • Point of View stick suport for looking around without headtracker(like simulation games)
  • External plugin support for PC based autopilot applications
  • Compatible with all Windows versions
I'm working on software alreadyThanks for readingMelih
  • Hello Melih Karakell
    I am looking for a compufly that can do 25 channels, is there any way to either combine 3 compufly's together on one computer or to build one? I am working on a conservation project and the parks need 25 channels on the air frame.
    Please let me know
    Brad
  • Hi..Thomas
    I did contact and ask question via email to endurance 3 day ago, but until now i didn't receive email from endurance. Did endurance sell PCTx in another store? I need that device. I plan to fly my FPV from my car. Could you help me please? I live in Indonesia
  • could you help me where I can buy (the Store) PCTx ?
  • This is too expensive.
  • Great, thank you Melih.
    Latest software works.
    George.
  • Hi Guys,
    About Your Questions:
    @George, please download the latest software from flytron.com. Latest version saying the reason of error message. No more water fall. It's only reason is wrong com port selection and you can configure it from software.
    @Genesis Factor:
    Our contact page working under IE, Firefox, Iphone (Safari?) and Chrome, I just tested them. can you give the name of your browser and version number please?
    dx8vb.dll  is a system dll and you should be an administrator when your register it.
    Administrator login is different then being an admin of software under windows. run the command prompt screen with administrator privileges (right mouse click and select "run as administrator"  now you are the administrator of CMD software under W7. and then type "regsvr32 dx8vb.dll" and press enter you will see the screen like "dll registered successfully" if you cant , search the "dx8vb.dll problem" of W7 on the google, millions talking about this.
  • ^^ Edit to above
    I'm running W7 however; exact same error occurs on a machine runninp XPsp3, running side by side doing everything the same. Without Compufly plugged in I get 'Com port' waterfall, with it plugged in I get the error message in the above post.
  • Hello Melih and All
    Sorry to trouble you with known issue however, I cannot find a fix using the solutions of others. I have followed installation steps as described on here and other forums but still get this error when I launch Compufly.
    "Access Violation at 00471BF7 in module 'Compufly.exe' Write of address 00000004"
    I have run the register joystick component as administrator (I log on as such, and open as etc..)
    I get a successful message when I implement dx8vb.dll
    I have the CP210x drivers installed and working correctly.
    Have you any more things for me to try?
    Could anyone direct me to a more comprehensive walk through of this or simular issues.
    George.
  • Any idea on a mac version of the software or do I have to make my own? No problem, just time consuming.
  • Hi Martijn,
    It's using Silab CP2102 chip, i'm using this chip since 3 years and it is better performance and flexibility then FTDI. And have linux/mac drivers ofcourse.
    Products ready, i'm just waiting for finishing windows control software etc. If you want to buy for writing your own mac code, welcome, i can open one item stock for you. just PM me.
