Using a Laser Distance Sensor for DIY Drones: My Experience & Some Practical Tips
Hi everyone 👋 I wanted to share some hands-on experience with using laser distance sensors in DIY drone projects, especially for altitude holding, obstacle avoidance, and terrain following.
This topic comes up a lot here, so instead of theory, I’ll focus more on what actually worked for me and what I wish I had known earlier.
Why I Chose a Laser Distance Sensor Instead of Ultrasonic
I started out with ultrasonic sensors (as many of us do), but quickly ran into issues:
Inconsistent readings outdoors
Poor performance in wind
Limited accuracy beyond short ranges
Laser distance sensors (especially ToF-based modules) turned out to be much more stable for UAV use, particularly when flying low altitude or close to objects.
From my testing, lasers give:
Faster response time
Better accuracy (cm-level or better)
Much more reliable readings in sunlight (depending on wavelength & optics)
Typical DIY Drone Use Cases
Here’s where I found laser distance sensors genuinely useful:
🛸 Altitude Hold (Low to Mid Altitude)
Perfect for:
Precision landing
Indoor flight
Hover stabilization under 20–30 meters
🚧 Obstacle Avoidance
Mounted forward or downward:
Detects walls, trees, poles
Works well with simple threshold-based logic
🌄 Terrain Following
Paired with GPS & barometer:
Laser gives accurate AGL (above ground level)
Much smoother flight close to ground
Hardware Setup (What Actually Worked)
I tested a few different modules, but settled on compact laser rangefinder sensor modules that support UART output (TTL level), since they’re easy to integrate with:
Pixhawk
Arduino
Raspberry Pi companion computers
Some modules I tried were from Meskernel. They offer OEM-style laser distance sensor modules rather than consumer rangefinders, which is actually a plus for DIY projects.
What I liked:
Small size & lightweight
UART protocol (easy parsing)
Long-range options available (useful for higher altitude testing)
Not sponsored — just sharing what worked for me.
Software Side (Arduino / Companion Computer)
Most modules output something like:
So integration is straightforward:
Read serial data
Filter with moving average
Apply basic sanity checks (outliers happen!)
Tips:
Use median filtering if flying over reflective surfaces
Clamp values when sensor loses signal
Always combine with IMU/barometer (don’t rely on laser alone)
Mounting Tips (Learned the Hard Way 😅)
A few practical lessons:
Avoid vibration – soft mount helps
Keep sensor lens clean and dust-free
Slight downward angle can reduce false reflections
Shield from direct prop wash if possible
Also: avoid shiny surfaces during testing — they will mess with readings.
Range vs Accuracy: Don’t Overkill
One mistake I made early was choosing a sensor with way more range than needed.
If you only need:
Indoor / low-altitude flight → short-range, high-accuracy module
Outdoor terrain following → mid-range ToF sensor
Mapping / special projects →long-range laser module
Meskernel has different distance ranges, so it’s worth matching the module to the use case instead of going “max range = best”.
Final Thoughts
Laser distance sensors are not magic, but for DIY drones they’re one of the most useful upgrades once you move beyond beginner builds.
If you:
Fly low
Care about precision
Want stable altitude data
Then a laser rangefinder sensor is 100% worth experimenting with.
Happy to answer questions or share wiring diagrams if anyone’s interested 👍 Would also love to hear what sensors others here are using.
🔧 Useful References
Laser distance sensor modules(OEM style)
UART / TTL integration examples: Arduino & Pixhawk docs
