Variable Pitch Quad Rotor - M/UAV
DIY project ranging from a 600cc 120HP etec Ski-Doo engine, UltraSport 254 tail rotors, extruded aluminum blades from Vortech, aluminum / steel tube structural components, and a carbon fiber reinforced polymer monocoque frame.
Oh and
Well there are several flying now, this being the most impressive
2.5 years and nobody has even attempted this yet? Real life gets in the way, but I'm the only dummy with big dreams? Guess I have to do this for real just so it can be "done"
Pictures soon, also some proof-of-concept video + my rotor diameter
https://www.youtube.com/watch?v=qvxfo5oGaPA
https://www.youtube.com/watch?v=Vy5Ky50eGJs
Still working on this, real life gets in the way. Someday I will post my progress.
Doesn't seem right, but four 48" rotors is the equivalent of one 16' rotor...
1400lbs static thrust???
Two 3-way gearbox, CVT on center axle. See here
I'm designing the monocoque fuselage now, but my main project is design of the blade roots and lead-lag damper plate.
The original blades for this aircraft are only about 12" long with a 2" chord, made of Roacell foam with a carbon fiber 'C' spar and tungsten weights for inertia. The new blades are 18" long with a 3.5" chord, made from a single piece of extruded aluminum. The roots for the new blades will be about 3.5" long, for a total blade diameter of 48".
The engine will produce 115 HP at the target RPM of 6000. Once the blades are built, I will begin testing to see what the optimum speed for lift is. The rotor with blades will be mounted to a pedestal built specifically for testing. The rotor will be mated to a 30HP 3600RPM electric motor, and lift generated will be measured by a load cell.
1
2
3
4
5
of 5 Next
