This is a pre-beta testing firmware.
It is suggested that you test it only if you know what you are doing and are able to take the risks on a breifly tested firmware.
This is a version of the Arducopter 3.0 release. It is 1:1 with it’s original firmware. So please refer to the Arducopter site and Diydrones forum  for more information on the software new functionalities:
  • Inertial Navigation for Loiter and Auto meaning much more accurate control
  • 3D navigation controller follows straight lines in all dimensions between waypoints
  • WPNAV_SPEED, WPNAV_SPEED_UP, WPNAV_SPEED_DN, WPNAV_ACCEL allows configuring speeds and acceleration during missions
  • “compassmot” to compensate for interference on compass from the pdb, motors, ESCs and battery
  • pre-arm checks to ensure all calibration has been performed before arming (can be disabled by setting ARMING_CHECK to zero)
  • GPS failsafe – switches to LAND if GPS is lost for 5 seconds
  • Circle mode improvements including “panorama” when CIRCLE_RADIUS set to zero
These are the release notes specific for VRBRAIN. Please read carefully:
  • The External GPS port and the Telemetry port have been swapped. So please invert the two ports to have both working again.
  • This firmware is only for standard PPM radios. Previous problems with Futaba and FRsky should have been resolved, please report any problems.
  • You will loose all previous settings, so please backup your parameters if you need to go back to 2.9.1.2
  • You need to make all pre-flight calibration routines otherwise copter will not arm. So proceed with:
    • Radio calibration through Mission Planner
    • Accel calibration via Terminal (at the moment via mission planner is not working)
    • Compass calibration via Mission Planner
  • Make extensive pre-flight checks before fliying
At the moment only QUAD and HEXA frames will be released, so please for any questions or suggestion refer to e.castelnuovo [AT] virtualrobotix.com
RC Radio compatibility list
All previous radio problems SHOULD be resolved, but as we don’t have all you should report any issues.
Before using RC radio verify in Mission Planner planner if there is any latency > 1 second or bad Jittering.
If there is don’t fly!
In the preflight check , control the radio rensponse also with already tested radio.
Software download links
Standard PPM with External GPS (UBLOX):
Standard PPM with Internal GPS (MEDIATEK):
Original blog post : http://www.virtualrobotix.com/profiles/blogs/vr-brain-4-5-and-arducopter32-rev-3-0rc6-ready-for-beta-testing
Wiki Manual : http://vrbrain.wordpress.com/
    Hi Mark if you want more info about the board send a mail to info@virtualrobotix.com
    Best
    Roberto
