VR Brain 5 (PRO) vs VR Micro Brain vs Pixhawk
3689610743?profile=original
3689611001?profile=original
* Pro is only on request and customizable , the PRO IMU could be also based on Maxim , Analog Device and ST mems. * The two expansion bus support indipendent i2c , spi and some some specific I/O for manage multiple chipset. On expansion bus it's available also wifi module with specific nuttx driver. Ask for more info.
As request from some user i try to do a matrix comparison chart , if there are some error on Pixhawk help me to correct please :)
3689611048?profile=original
After the VR micro Brain 5 here finally get the VR Brain 5.
Sorry for the long wait but we had to work a lot on the operating system, new driver and all the infrastructure to support the mission planner firmware repository.
Today the board is  available on the store.
Here are the first pictures of the oem version, I prefer to show you the board without enclosure because  it's a jewel of technology :)
It will initially be available in the basic version. Only for more experienced users that join our advanced dev program will be available version that supports up to 3 SPI IMU  with (Acc , Gyro , Magnetometer and barometer ) . In advanced configuration the board support until 2 VR Multiconstellation GPS Ublox 8
Provides CAN Bus with driver on board, SD Card, and realtime operating system NuttX RTOS operating sysyem.
Full tech specification :
Hardware:
  • CPU:
    • ARM CortexM4F microcontroller with DSP and FPU.
    • 1024KiB di flash , 192KiB of RAM.
    • 1 SD Card Slot support until 64 gigabyte.
    •  Jtag support for onboard realtime debugging.
  • IMU Sensor:
    • mems accelerometer and gyroscope (different option , available pro certify ,too )
    • barometer with  10 cm resolution.
    • 2  SPI expansion BUS for optional IMU
    • 1  sonar input.
  • RC
    • 6 RC INPUT standard PPM.
    • 1 PPMSUM
    • 1 ARM Switch
    • 1 SBUS input compatible with  Futaba and  FRKSY technology.
    • 8 RC output ( 60 - 490 hz ) , 4 optional RC output ( in SBUS mode)
  • Expansion BUS
    • 1 CAN BUS .
    • 2 serial port for interface VR GPS Ublox 8
    • 1 i2c bus for magnetometer connection.
  • Additional IN - OUT
    • 3 Output Switch digitali (ULN2003) 2 LED 1 BUZZER.
    • 1 input for voltage control.
    • 1 input for current control.
  • Dimension 6x4.
  • Available plastic and aluminium case as option.
IDE and development kit .
  • Eclipse IDE.
  • Arm GCC Toolchain.
  • Support real time debug .
Firmware:
For this platform are available many libraries developed by the community Virtualrobotix and Diydrones.
Native support of the operating system Nuttx rev 6.20 to 7.30.
Bootloading and Automatic Update standard and custom firmware.
Repository Server with native support Mission Planner 32 and 64 bit.
The supported UAV firmware are  : APM Copter, Plane and Rover
Our dev team support and improve VRBrain NuttX operating systems and AP_HAL_VRBRAIN . The Hardware Abstraction Layer for integration with APM firwmare enviroment.
The mini site is available at :
http://vrbrain.wordpress.com/
For more info send a mail to : info@virtualrobotix.com
The link where you can buy the board and find more info is this:
http://www.virtualrobotix.it/index.php/en/shop/autopilot/vrbrain5-detail
For this product is available a professional customer support program. University and Research Lab use VRBrain 5 in advanced research project. Join to our pro dev team today :) Some company that want certify their drone ask the support to our dev team for support during the qualification test .
For more info send a mail to info@virtualrobotix.com
original blog post : http://www.virtualrobotix.com/profiles/blogs/vr-brain-5-0-after-some-month-of-waiting-the-new-professional-vir
    @Gary
    I'm happy that you like our 3 option VR Brain solution. About the US distributor send a mail to info@virtualrobotix.com for more info about :)
    Best
    Roberto
    @Bill,
    i think that could be possible to use on Brain and Micro the ULN2003 output , you can connect the ground ad +5v so you can trig your chdk . I spoke with Marco Robustini , too about this option , it's only a small firmware patch . Best Roberto
  • Looks great Roberto,
    I will link this Blog on my Drones Are Fun Web Site on the Autopilot Page here:
    http://dronesarefun.com/AutoPilots.html#Autopilots
    The options of micro, full and pro are really excellent.
    I think you need a US distributor, receiving parcels from Italy can be sub-optimal.
    Best Regards,
    Gary
  • The Pixhawk is a 3.3 volt unit and will not trigger a CHDK camera without being modified to provide the 5 volts required to trigger the camera. Can the VR Brain trigger a CHDK  camera without modification?
    Hi James,
    i'm doing some test with micro brain and arduplane , but not in air .. i think that the next week i try on E-Fly 180 a very small plane :) On X 8 I'already tested with VRBrain 4.5 and it fliying very well :)
    I Update the community about my building log , on Micro Drone i have a doing a lot of great test :)
  • I'm actually looking for a control board for a small plane. Do you guys have any demonstrations of your boards working with Arduplane?
  • Now I'm getting lost between VRBrain, Pixhawk and Dropix....all looks promising
    @bocorps,
    the board is sell with Plastic enclosure. We are working to aluminium option It will be available in the next month.
    @ALL
    I'm working on matrix table : VRBrain 5 - VRuBrain 5 and Pixhawk.
    @mP1 ,
    on hardware available 8 PWM input as VR Brain 4.5 , on firmware in actual revision only 6 , we are working for implement also the other 2 channel . On SBUS and PPMSUM are available 8 channel or more .
    best
    Roberto
  • I'm Looking forward to the matrix.  I'd also like to see what power modules and other peripherals it connects with (current and voltage sense, telemetry, etc) ... I don't see a bunch of DF-13 connectors
