Dear Friends,
yesterday we start to delivery the VR Brain Micro 5 pre order. Thanks to all guys that join the preorder in last month . I think that the first user start to receive it in the next days . We are working to update the wiki with the updates for quick start FAQ for use our new board.
The info will be update in the next hours on :
vrbrain.wordpress.com
This is the repo with bootloader , driver , updated code for vrbrain micro 4.5 and 5.0
https://github.com/virtualrobotix?tab=repositories
this is internal repository where we ask the pull request to diydrone global repo .
On last mission planner we yet propagate the last patch for work with uBrain .
If you need support write down in this blog post or in virtualrobotix original post :
best
Roberto
Just received my VRbrain 5.1 Micro here in New Mexico! I just put in zeros for the partitia IIRC. Much faster delivery than I was expecting, can't wait to try it out!
normally is better to use external bec and connect it to servo .
I'd like to order one to be sent to the USA. I can't signup because I don't have a VAT / Partita number. Please advise!
Thank you Roberto.
Happy packing & shipping ;)
Hi Paul in a week i think that will be open the order for VRBRain 5 ... now we are doing a kickoff for VR uBrain 5 because start to deliver the may pre order .
@Danny ,
we re open the pre order now check here if you want to buy a micro brain , for support i'm available in skype at address : virtualrobotix
http://www.virtualrobotix.it/index.php/en/shop/autopilot/vrbrainmic...
best
Roberto
Hi Marius,
try to reply to your questions :
1) The main difference VR uBrain and VR Brain are :
The dimension :
the micro is for small drone only 9 gram 3.7 x 3.7 a good product for oem integration .
Micro don't have double sensor option available on standard there is double option available on GPS , INS , Baro.
The micro don't have can bus , the standard have can bus.
Micro don't have enclosure , Standard have two option for enclosure Plastic and Alu.
Micro have on board a telemetry option standard don't have it onboard.
Standard have a mechanical vibration damper as option on micro is not possible.
2) Normally we produce two board revision for year the number 4 is the year until start VRX Autopilot project . This is the fith year so the board is marked as 5. Version five is update respect of experience doing with 4. A lot of improvment and differenciation in two size micro and standard.
3) I need a lot of time to explain difference ... i write a small doc and then share :)
best
Roberto
Hello Roberto
looks like you are going to be the pixhawk alternative for non-US customers.... and deservedly so
Can you put VRBrain 5 for preorder on your online shop?
Forza Italia.....
Hi Roberto - I am in the UK and am interested to know when we can hope to see availability in the UK for the VRBrain Micro or VRBrain 5. It is great that this product assures that Arducopter continues to grow and be available on different hardware platforms.
Hi Mark ,
on 250 airframe normally don't there are so much vibration .. i fix my VR uBrain with classic MK style dumper . But yes you need to cut mechanically the vibration on your frame ... we are working on a special frame upgrade of last one that cut a lot vibration also on the camera .
Follow the instruction on the wiki for your first quick start we try to update using the feedback of first user .
the wiki is here : vrbrain.wordpress.com
Best and thank you for choose our VR uBrain.
Roberto
1
2
3
of 3 Next
