Today i create a Google Community Group for manage the beta testing of VR Pad Station this is the link :
http://plus.google.com/communities/102697330643558260161
This is the official Virtual Robotix Discussion group about VR PAD Station 2.0 :
http://www.virtualrobotix.com/group/vr-pad-station-2-0
We upload the last revision of VR radio RC . The new name is VR PAD Station 2.0 . We integrated the mavlink 1.0 telemetry function with original Virtual RC project so now is possible to use VR PAD Station as tools for :
- Receive telemetry from drone.
- Setting Parameter .
- Change Flight Mode.
- Set waypoint.
- Send direct command as Return to Landing point , Land or Guided mode.
- Virtual Remote control with a lot of advanced feature for setup the radio stick
We are work in progress with some advanced feature as Special Follow me mode , Fligh log book and VR Gimbal integration.
The App is compatible with APM Copter , Plane and Rover.
Inside the community could be possible discuss directly with developer about the new request feature .
After join the community could be possible download the APK in a special section of google play
This is the direct link to google play store beta registration:
https://play.google.com/apps/testing/com.laser.VrPadStation
If you yet register in the community appear this message ....
If your registration accepted you can download the beta testing of our application :)
Feedback about our application are welcome ... :) In the next week we intend improve a lot the application with new feature under development.
Credits about Opensource component :
The VR Pad Station it's a framework of advanced opensource tools and library from different source :
the mavlink comunication library and it's original user interface is a fork of great work doing by Arthur Benemann and his team in rev 1.0 of droidplanner .
The library used from video decoding is a wrapping library from : opensource VLC project.
The GPL code modify and improve by our Team will be release in the next days at this address :
https://code.google.com/p/vr-pad-station/
Best
Roberto
Connection to the copter works.
At first glance, the parameters are not in alphabetical order.
Is there a setting?
Peter
Thank you, Roberto.
Has worked.
Peter
I registered with my Android tablet as a tester.
I was then forwarded to the Play Store. There the message "not found" came.
Do you not have an simple direct download link?
regards Peter
So the problem could be that you have a multiple google user and when you try to download is not signed with same user respect of user signed in beta testing community ..other have same problem ?
best
Roberto
Hi Roberto,
I signed up as a beta tester.
If I then try to Download the app it comes an error "not found".
regards Peter
Hi Peter ...
the problem is simple to solve before to going to software link you need to join the beta tester community :
... this is standard approach defined by google and hardcoded in the Beta Application .
best
Roberto
This is way too complicated.
Is there an easy way?
regards Peter
Don't assume that DJI does everything for logical reasons. Their latest flight controller, the A2, will still take-off and fly up to 20 feet altitude, and land, if you flick the RTH switch while it's sitting on the ground at home.
yes droidplanner and andropilot work well on my zopo
it s the first time i have this kind of problem :(
my android is 4.2.1,,,,,
@All
thanks to join to our beta dev program in 15 hours we are near 50 new member that's fine :)
Feedback about first impression are welcome. The next week we are working on online manual and for improve the integration with virtual rc and for add some usefull functionality now under testing .
