There are three operation modes for agriculture drones during spraying. Manual Operation Mode, A-B Route Operation Mode, and Auto Operation Mode. Today, I will take the Z series holistic system solution as an example to share how to operate the manual operation mode with you.
Step 1. Open Agri Assistant App on remote controller, click Connect> H12/MK15 >Start.
12144048677?profile=RESIZE_710x
Step 2. Tap “Spray” in the top information bar, set Spray Type to “Spray Auto” , set the Hec Dosage and Disc speed, then switch Spray type to “Spray Manual”, tap screen to confirm. Take off the aircraft in the Attitude Mode, fly to the field, switch to the Manual Operation Mode, then operate the aircraft by sticks, press C and D to spray.
12144049062?profile=RESIZE_710x
12144049087?profile=RESIZE_710x
The manual operation mode can apply to various complex fields, but it requires skilled flyer to operate. In the next article, I will introduce a simpler spraying work mode to you guys. If you have any question, welcome to share your opinion.
 *The above steps are for reference only.  Please refer to product use manual when using.
