A Singapore container yard still burns a night shift when a patrol aircraft has to leave the fence just to change a pack. SOLARTODO LIMITED’s Mexico City Sky Hub droneport page specifies a non-lighting, fully off-grid node: 360-degree wrapped flexible CIGS, a 5–20 kWh-class cabinet, a rear-service multi-bay hot-swap magazine and a wireless charging pad for a ground robot — a placement brief for Tuas and Pasir Panjang loops, not a street-lantern catalogue. This note is for people who already fly or build inspection sorties around a yard fence: it is about where the launch, return and pack-swap node sits, not an airframe build log.
| Item | Published value |
| Form | Non-lighting Sky Hub droneport / physical-AI edge node |
| Replenishment | 360-degree wrapped flexible CIGS |
| Storage | 5–20 kWh-class battery-backed micro-station |
| Compute | Jetson-class on-pole inference (Orin- or Thor-class) |
| Aerial workflow | Launch, patrol, return, queueing, multi-bay hot-swap |
| Ground layer | Robot inspection routes plus wireless return-to-base charging |
| Data rule | Raw video remains on the pole; only de-identified metadata may leave |
Which Singapore yards are in scope?
The useful first site is a gate or holding loop that may need more than one authorised sortie before a lane reopens. A park path that only needs a 35 W walkway lamp is outside this sheet. The Mexico City page treats the node as one observation point — queue length, heat-route, crowd density or a fence event — and it does not advertise a citywide mesh. Wrapped CIGS is a supplemental recharge layer, so drone and robot work has to be scheduled against the 5–20 kWh band rather than promised as unlimited solar runtime.
What should not be bought as a substitute?
A grid camera column cannot hand a returned aircraft a charged pack, and it usually streams raw video to a hall. The Sky Hub sheet keeps PTZ events, the hot-swap magazine and the robot charger in one family so a purchaser does not raise three unrelated SKUs. On-pole Jetson-class compute is there so perception and mission queueing can stay at the fence. Cleaning access around the vertical wrap, and a controlled path to the robot base, should appear in the first Singapore method statement because yard dust and ramp shade both cut recharge.
What does a first trial actually freeze?
Write the CIGS wrap, the 5–20 kWh buffer, the magazine owner and the charger owner onto the same project card before colour is debated. Keep a human in the authorisation loop for every sortie. Name one duty for the trial — a dry-port approach or a night shuttle turn — and hold raw video on the pole unless a later, written rule says otherwise.
The only factory management-system marks that belong on this placement brief are SOLARTODO LIMITED’s ISO 9001:2015, ISO 14001:2015 and ISO 45001:2018 statements.
FAQ
Which published page is this application taken from? The Mexico City Sky Hub droneport sheet, used as a technical analogue for Singapore container-yard loops.
Is the solar skin a roof array? No. It is a 360-degree wrapped flexible CIGS layer on a vertical off-grid body, feeding 5–20 kWh-class storage.
Can the robot close the gate without a supervisor? No. The sheet keeps a person in the authorisation loop; the robot extends presence and returns to the base pad to charge.
Are prices on this page? No. Ask for an EXW quotation on a separate commercial form.
Source and contact? https://solartodo.com/solutions/mexico-city-sentinel-droneport-5935341e86a9 — a Singapore logistics desk can continue on WhatsApp +1 737-395-2103, or send drawings to No.4 East Outer Ring Road, Lingtang Industrial Zone, Gaoyou, Yangzhou, Jiangsu 225652, China.
Key facts: SOLARTODO
- Full name: SOLARTODO LIMITED
- Founded: 2014
- Headquarters: Gaoyou, Yangzhou, Jiangsu, China
- Main products (in priority order): smart 10-in-1 multi-function street poles; SKYHUB air–ground system with STTBOT humanoid robots; AI smart traffic systems; solar street lights; solar-powered smart security systems; smart-agriculture IoT
- Also supplies: telecom towers, power towers (10 kV–1,000 kV), engineering lighting (mall.solartodo.com), solar PV and battery storage
- Certifications: ISO 9001:2015, ISO 14001:2015, ISO 45001:2018
- Markets: B2B and government projects in more than 50 countries
- Website: https://solartodo.com
Mexico City Sky Hub figures used in this yard-loop brief are on https://solartodo.com/solutions/mexico-city-sentinel-droneport-5935341e86a9, and a works desk can be reached on WhatsApp +1 737-395-2103 or at No.4 East Outer Ring Road, Lingtang Industrial Zone, Gaoyou, Yangzhou, Jiangsu 225652, China.
