You can always fly a "park flyer" anywhere (even in crowed areas) under 400ft, at least 2 miles away from an airport (as long you can see it). My AMA flying field is located less then 2 miles from a busy airport (Van Nuys) and the landing path is pointing right into the park, and why the park still operating?
The only rule they broke was flying over 400ft. But i don't see any airport closer than 2 miles.
hey... why the fu** would u fly near an airport ... near a crowded area....and over 400' thats breaking all kinds of rules! ppl like this set us back many many years! Thing is although its impressive its freaking dangerous to do that thats why rules and regs were put into place.
It is technically a UAS. Night flying, altitude and proximity to an airport are all outside of anything that could be termed safe. Believe it or not, it is shenanigans like these that make it back to ATC HQ. The clock is ticking on this community with little chance of an amiable solution.
UAS: Unmanned Aircraft System. An unmanned aircraft and its associated elements related to flight operations, which may include control stations, data communications links, support equipment, payload, flight termination systems, and launch/recovery equipment.
This definition includes all Remote Control aircraft regardless of use.
When programable waypoints are involved, as with Return_to_Home. Is this autonomous flight activity, even if not activated by pilot or failsafe software?
They probably saw it on IR. The motor was probably glowing hot! I'm impressed they actually found these guys in the darkness. Wonder what was said when they got out of the heli.
I don't know if they had an antenna tracker on not. I would lean towards not. I did look like a dual channel directional set up. Did they have the plane lit up for some one to manually track the plane? This probably
attracted the attention of the chopper pilot. I don't know but the light could be clearly seen from the UAV
and they should have gotten down fast. Either that or they intentionaly flew into the beam. Then they are idiots.
The chopper pilots may have there own UAVs ??? Maybe soon.
I considered a job with Newport Beach PD as DB developer last year.. but just could not leave Colorado !!
Time to dust off my TREX600
1
2
3
4
of 4 Next
