XUAV Clouds build part 2 :
Clouds is a twin motor UAV. Total weight with full payload could get as high as 4Kg.
For an easy hand or catapult launch, a 1:1 weight/power ratio would be more than enough.
This means using two motors producing each a maximum thrust in the 1.8-2Kg range.
So what motor, propellers, battery voltage then to use ?
Check the previous build video,
XUAV Clouds Build - Part1: Wings : https://youtu.be/3CkiUq-qIeU
Great! Thank you for sharing it!
