You may have seen my 310 haxa build a few months ago but I decided to see how big I could go so here we go
its 580mm has 4 400kv 22pole motors 14x9 propellers can hold up to a 16000mah battery has afro 30 esc's on a 4 cell 2200mah battery it flies for 15 min according to the calculator with a 16000mah battery it should get 40min flight times have not tried it yet still waiting for the 16000mah battery
Those are some pretty good flight times. Do you know how heavy just the frame is?
Under 3 lbs
I will try and get some flight footage today and post it
Actually they are shortened I had trouble finding a 14x9 so I shortened a 15x9 and rebalanced them I ordered a tatty 16000 and a venom 16000 both 4s to test with the tatty is 15c the venom is 30c also ordered at 10000mah for testing the 10ah is way cheaper might modify thevfeamevto try and fit 2 10ah for cost reasons
Bart, those motors are supposed to be like that I believe, I remember seeing them on hobby king.
Also question for OP, what is the 16000mah battery you are using?
it looks as if the tips of the propellers are cut off?
