Warning #2: GPS glitches can cause sudden and aggressive position changes while in loiter mode.  You may wish to reduce the Loiter PID P to 0.5 (from 1.0) to reduce aggressiveness (see image below of where this gain can be found in mission planner).
Warning #4: loiter turns does not maintain altitude.  This bug will be fixed in AC-3.0.2.
  • Safety improvements:
How to upgrade:
2. Click on the MissionPlanner's Hardware, Install Firmware screen.  The version numbers should appear as "ArduCopter-3.0.1", then click the appropriate frame icon and it should upgrade as per usual.
3. Reduce the Loiter and Alt Hold PIDs if you have modified them from the defaults.  The modified PID values for the 3DR frame can be seen in the image below.
4. Although not directly related to this release, if you purchased an APM prior to March of 2013, update your PPM encoder to the latest firmware (instructions here).
Special Thanks to MarcoDaveC and the large number of testers on the pre-release thread who put their copters at risk during the extended testing period.  Some of their videos can be found hereherehereherehere and here.  Thanks also to MichaelO for the MP changes required for this release.
Well done!
congratz randy for release, finally.. it's been long run but now it's here.
Very Well, I still can't test it. Because, Thailand have a raining everyday. But,If have without rain I'll test it and share video to our for look.
What is the expected magfield value for APM1?  I still need to disable the pre-arm checks as my magfield is around 177/178...
Is there a changelist from 3.0.0?  My hexas are flying (in an airplane) to Costa Rica on Monday for ecological surveying, and I'd like to know if it's important that I update them from 3.0.0.  Thanks for all the hard work!
Yes, there are a number of improvements and fixes that are worth updating for if you have been flying 3.0.0.
Stephen,
     Generally I think you should stick with what you know (i.e. 3.0.0) if it's been working well for you but there were a few important changes that went into 3.0.1-rc1 related to dealing with GPS glitches.  See below in bold.
Improvements in AC-3.0.1 over AC-3.0.1-rc1
1) Rate Roll, Pitch and Yaw I fix when we hit motor limits
2) pre-arm check changes:
    a) double flash arming light when pre-arm checks fail
    b) relax mag field checks to 35% min, 165% max of expected field
3) loiter and auto changes:
      a) reduced Loiter speed to 5 m/s
      b) reduced WP_ACCEL to 1 m/s/s (was 2.5 m/s/s)   <-- will reduce response to GPS glitches
      c) rounding error fix in loiter controller
      d) bug fix to stopping point calculation for RTL and loiter during missions
4) Stability Patch fix which was freezing Rate Taw I term and allowing uncommanded Yaw  <-- only important if you have some motor imbalances (which it doesn't sound like you do)
Improvements in AC-3.0.1-rc1 over AC-3.0.0
1) bug fix to Fence checking position after GPS lock was lost  <-- very important if you use FENCE
2) bug fix to LAND so that it does not attempt to maintain horizontal position without GPS lock  <-- quite important if you ever lose GPS
Andre,
     ah darn.  I made it wider so it's now 192 ~ 907 for the APM1 but that's still apparently not quite enough.  It seems like for the APM1 the field can be either 330 or 550 depending upon whether you're using the 5843 or 5883.  Sorry about that, I'll sort it out for 3.0.2 (or 3.1.0 if we're lucky enough to get away without a 3.0.2)
Thanks Randy.  Since I only have a few days, I'm going to stick with 3.0.0 for the trip.  One of my copters, "Crimson", has over 6 hours autonomous flying time logged on 3.0.0 already.  No crashes since I built it and loaded in 3.0.0.  The other one I'm sending "The Red Baron" has probably under an hour, but it is identical in build and its test flights have all come back beautiful.  So thank you for making a great firmware.
Randy,
No worries it's not a train smash.  I think the lowest I've seen it go to was about 170...
Great Job!
Randy, does this release contain the relaxed accelerometer settings?
apm2.0 3.0.1
offsets more than 3 seem not to pass
