Had a chance to compare the Naza M to AMP 2 this weekend and wanted to share the experience.
The comparison was done on two similarly sized custom built quads at ~24" span running the same props, motors, PDU and ESCs. The Naza quad had a Go Pro and Fat Shark FPV 5.8Ghz Transmitter and weighted in at about 3.1 Lbs. The APM Quad (mine) had no additional equipment besides a Sonar and it weighed about 2.75 Lbs.
In general both performed very well with a nod going to the Naza in Loiter, RTL and auto landing due to what appears to be a better GPS. Clearly APM has auto mode and Naza does not.. for the price the APM appears to be a solid value.
Stable Mode
As expected both quads were equally stable with no real noticeable difference in stability. The only big difference was NO TUNING on the Naza... it just worked out of the box.
Loiter
The Naza quad had a noticeable difference in loiter stability and accuracy. Granted my quad my not be tuned perfectly but the Naza held its position more accurately and with less twitching in the wind to do so. The Naza's corrections to the wind seemed to be invisible.. where the APM corrections were noticeable in both pitch and prop noise.
RTL
We did a RTL comparison taking off from the same spot and flying about 100 yards away at about 35 feet. The Naza returned to the exact spot of take off. APM got within 10 feet (see below).
Auto Landing
Testing the auto landing during RTL..... the Naza descended from 35 feet in what appeared to be about 5 foot increments. It was a very controlled decent. It landed perfectly on home and shutoff. As mentioned the APM quad hit the launch point within 10 feet. Its decent to landing was steadily and constant. When it touched down it then proceeded to skip around on the ground and went another 10 feet from its landing point before shutting down.
AutoPilot
The Naza has no autopilot. I finally got all the gremlins out of my APM and flew several successful missions which was very cool.
Cost
APM is ~$200 with GPS and Autopilot
Naza is ~$240 + and additional ~$160 for GPS. = $400
Tags:
Great comparison, John! I've been hoping someone would do that (I don't have a Naza myself). I think we should benchmark against DJI and endeavor to match their performance at a fraction of the price (and with an open platform). Sounds like we have some work still to do, but I think we're closing the gap.
I'd love you to do the same test on the next version of the code (2.9) when it's out in a week or two. Also: are you using the uBlox 6 GPS? That will give much better loiter/autoland results than the built-in MediaTek. If you don't have that, I can send you one so for your next test.
Permalink Reply by John Dell on November 27, 2012 at 1:32pm Chris,
Glad to do some additional testing on 2.9. In terms of the uBlox.. I bought one a few days ago taking advantage of the sale... so no need there but thanks for the offer.
I would say the the ability to run missions on the APM is certainly a huge differentiator and value adder... the downside is the tuning. For those who like tuning.. no issue.. for those who simply want to fly its a drag. I have had my APM 2 since April and I am really just now starting to get really comfortable.. and that was after a few set backs and a few months on the shelf. (Note I came from the multi-wii platform so I was not really starting from scratch) . The Naza came out of the box and was running great from flight 1.
Your goals of matching performance at half the price is a fantastic goal. I think the gap is closing. It seems every release some things get better some take a step back.. but the progress is certainly steady. The team has a lot to be proud of and a lot to work on.
Personally, I think APM has much more upside. Being able to run missions, interface with other sensors, the open possibilities of the code and trigger servos (once that is fixed) are features that would keep me interested. Naza flys great and if you can match that with the added functionality APM has, there would be no question as to the value.
Permalink Reply by John Dell on December 18, 2012 at 8:49am Did some additional "testing" and comparison to the NAZA the other day.
I installed the UBlox GPS and the performance in RTL has improved significantly. The quad returned to within 2 feet of the launch and the rate of decent and landing were nearly comparable to the Naza. No more skipping around when it landed.
I recently started FPV on this Quad and the learning curve is steeper than I thought it would be. My friend is also learning FPV on his Naza quad and one feature that seems to help him quite a bit is flying around in Loiter / GPS Hold.
On the Naza this flight mode gives rock solid altitude and position hold even at low altitudes and the quad is still flyable. Let go of the sticks and it is "stuck" where you let go. This is helpful in FPV as I found some disorientation and difficulty gauging rate of ascent / descent. Stopping to collect your thoughts without the fear of the quad drifting around or changing altitude is very comforting.
With the APM in loiter or Alt Hold modes you loose a lot of control on the altitude adjustment. This is fine if you are flying in wide open spaces but if you want to change altitude for any reason you need to change out of the flight mode and reset your altitude. I know you can adjust altitude in these modes, but when you switch out of them your Quad is either falling to earth of flying away really quickly.
With the NAZA you can simply adjust altitude in GPS hold and the quad adjusts appropriately.
Flying in loiter mode is doable but it feels different. When adjusting the position in loiter my quad seems to want to "rebound" back a few feet. With the Naza the quad simply stays where you left it.
I know I am probably comparing apples to oranges in the way APM and NAZA handle adjustments to Loiter / Alt Hold, but personally I think the way NAZA approached them is a bit more intuitive. Since you can essentially fly in GPS Hold on the NAZA there really is no need to switch out of it and if you need to you can just let go of the sticks and the Quad will be where you left it.
I also know I am probably trying to get the APM to behave in a way the flight modes were not intended so the comparison may not be fair in those regards either, but a new or improved flight mode that behaves the way the NAZA does would be beneficial to me.
Permalink Reply by George Brindle on December 18, 2012 at 9:34am I certainly agree with you regarding flying in the Loiter mode. Having seen the way the Naza functions, having that locked feature would really be the icing on the cake
Permalink Reply by Kevin B on December 18, 2012 at 1:13pm While naza GPS mode can help in some situations, most of my 'naza buddies' say alt mode is more practical for everyday FPV (because it's more responsive in X/Y). That said, my APM2.5 holds a loiter as good as naza... it's just the alt hold that gets larger errors when accelerating around (talking 1-1.5m max). I have a personal agenda to bring buyers remorse to my close buddies who fly naza... I'm a newb with autopilots, but I can assure you I have good piloting skills, and I've already logged plenty of tuning time. I think all I need is better info to get there. ;)
Unfortunately the tuning process has turned out to be very much guess and check affair. Existing info on tuning alt mode is too limited and vague. I think Dave C's rate/stab tuning guide is along the lines of what we need... a layman's guide with info on what to look for, more exact descriptions of what each parameter does, and of course discovery of independent parameters (like Dave observed with "rate D"). Recently throttle acceleration got thrown in to the mix... just more variables on top of this black box. The subject of alt mode tuning needs a lot more clarity.
Permalink Reply by John Dell on December 18, 2012 at 7:07pm Kevin,
I agree with all of your points, ALT Hold should be better flight mode, but while in learning mode for either FPV or in general, the GPS Hold is a good safety net.
I also agree the Alt Hold is far worse on the APM vs. Naza.. not sure why, my setup, tuning ect..
Withe the UBlox GPS the loiter is nearly the same on both the Naza and the APM, but I still think the Naza has a slight edge.
My friend who bought the Naza also bought an APM 2.. its been in the box for 6 months as he was tired of hearing me complain about the tuning and random challenges. I have come around in recent months (now that I have it flying really well after 8 months of trying)
As I mentioned given the cost and the additional features you get with the APM its a better value, but it comes with the cost of a lot of tuning and patience.
If APM changed the altitude response for ALT Hold it would be very competitive with Naza.. additionally a "SUPER STABLE" mode could be developed allowing you to fly in Loiter mode and allowing a better altitude response I don't see much justifying the cost of a Naza for most of the market.
Hi John Dell,
I would like to ask how you interfaced the uBlox GPS to your APM 2.0. I also have the APM 2.0 that's been on the shelve for about 6 months now and I'm just starting to build a quad for it; would like to know how the stock Mediatek GPS perform on the quad and what are the steps to change the GPS to uBlox.
Great comparison between the Naza and APM. My buddy also has a Naza on his quad and it's solid in Alt Hold and Loiter. The reason I'm recommisioning my APM 2.0 is to go head to head against his Naza.
Permalink Reply by John Dell on December 19, 2012 at 11:55am Gent... Here you go.
http://code.google.com/p/ardupilot-mega/wiki/AMP2GPS
Let me know how your H2H battles with the Naza go. With proper tuning I'm sure it will hold its own.
Thanks! Will let you know as soon as we do it.
Permalink Reply by Marc on December 23, 2012 at 5:28pm I would say the APM is superb value for money guys, and we have autopilot, and the open platform means it will just get better and better, my hats off to the developers and all the people that put into it, and yes the naza just works but whats the fun in that i like tweaking the settings as im learning all the time... :)
Permalink Reply by criro1999 on December 18, 2012 at 10:00am APM Auto Landing: "When it touched down it then proceeded to skip around on the ground and went another 10 feet from its landing point before shutting down"
This is exactly the same behaviour on my quad. APM never shut down motors at first contact with ground. When is trying to skip around, then it can flip since the some arms could have ground contact.
When I do Auto landing, I did switch myself from Auto to Stabilize and lower the throttle stick in the same time, to avoid jumping (and flipping).
Is any solution to assure that once the ground to hit, to stop automatically (some PID adjustement) ? Otherwise I can not trust a real Auto Landing without my manual intervention.
Season Two of the Trust Time Trial (T3) Contest has now begun. The fourth round is an accuracy round for multicopters, which requires contestants to fly a cube. The deadline is April 14th.185 members
6 members
129 members
87 members
24 members
Powered by
