Problems with Radio Calibration
I could use some help!
I am using the Futaba R2008SB receiver with the PX4.  When going through the wizard, I am unable to both test the motors nor calibrate my transmitter as it is not responsive to any movement from the control sticks.  The transmitter and receiver are "binded" and the receiver is powered from the power module, which is connected directly to the battery.
What should I look at to his this issue? Could it be an ESC issue?  Is there something in the setup that I miss?  Any help would be greatly appreciated.
