Hi Guys,
I am using the PX4 FMU V1.7.2 with IO V1.3.1, QGC 2.0.3beta, the latest QGC firmware, Quad with 4 x 40A SimonK firmware ESCs and 2815-470KV motors.
The installation/setup was straight forward, the firmware was updated smoothly, the RC and sensors calibrations all went well, when I try to arm the PX4, it will showing armed in the QGC, all radio inputs can be seen from the Mission page, but the motor doesn't spin at all...:( It's like the ESC is totally not armed, no sounds ever came out of the motors...
I have tried the same setup with the PIXHAWK I have, same result, all okay but motors never spin.
Tried both setup with Mission Planner and both 3.1.5 and 3.2.0-RC5 firmware, all working fine, didn't test all features fully but at least the motor spins fine when armed/throttle advanced...
So my questions are:
- Is there something wrong with the QGC firmware or it's something obvious I haven't done?
- How do I calibrate the ESC under QGC firmware? (I have done that manually via radio. I know how to do it with AC3.x firmware but not with QGC firmware)
- Any feedback of how the QGC firmware performs are really appreciated.
Thanks in advance!
Hunter
Found out what was the problem, for someone who might experiencing the same issue, it was because the airframe model was selected wrong, and the /etc/rc.txt, /etc/config.txt files not created on the SD card.
I got same problem with you, but I could not solve my problem with your answer...
Therefore, I want ask you some questions.
1. What airframe model you chose for your quad?
2. I checked my SD card and I do not even have etc folder. Should I create etc folder and txt files myself?
1, 4001 or 4011
2, yes, that what I have done.
Thanks your for your answer.
May I ask u one more question?
Are you sure with that I should create even the rc.txt file??
What I read on the px4 document said that the rc.txt file make the system unable to start.
Also, I created the config.txt file myself, but I have no idea what should I write down on the rc.txt file.
Could you give me some examples or could you attach the file you made?
Thank you Wang!
No sorry, you don't need the rc.txt anymore, the autoconfig will do most of that for you. Just config.txt will be fine.
I don't have the PX4 with me ATM, will upload my config.txt later.
My /etc/config.txt file:
# Generic Quadcopter x
set VEHICLE_TYPE mc
set MIXER FMU_quad_x
# PX4IO PWM output will be used by default
set PWM_OUTPUTS 1234 # Change parameters for the first 4 outputs
set PWM_RATE 400 # Set PWM rate to 400 Hz for better performance
hmm... I tried, but I failed my motor to spin.
I cannot understand that other ppl easily make the px4 work with QGC, but why I can't??
Thanks any way Wang. I guess the cause of my problem is different thing.
